I am trying to build a specific package which requires the best possible performance, so I want to pass flags like -march
and -mtune
. I found this wiki page about build flags. So I’m trying to build the example from that page for my CPU:
pkgs = import <nixpkgs> {
localSystem = {
gcc.arch = "znver3";
gcc.tune = "znver3";
system = "x86_64-linux";
pkgs.openssl
I’m building this with the following command:
sudo nix-build test.nix --option system-features gccarch-znver3
But even this simple package fails to build.
Edit: I guess I’m just running in to this issue: Build failure · Issue #162 · besser82/libxcrypt · GitHub. Using <nixos-unstable>
seems to work better. Let me try that with the thing I really wanted to build.
By the way, is there a way to only build the package itself with these options and not the build tools like gcc and perl?
