Running nixos 25.11 and several other distributions all of which can be booted to the desktop using custom kernel compiled using Debian 13. Nixos firewall fails during boot but nixos appears to function as expected otherwise.
journalctl throws this error information:
journalctl | grep firewall
Dec 30 17:25:16 nixos systemd[1]: firewall.service: Deactivated successfully.
Jan 12 16:55:17 nixos systemd[1]: init.scope: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
Jan 12 16:55:17 nixos systemd[1]: init.scope: (This warning is only shown for the first unit using IP firewalling.)
Jan 12 16:55:18 nixos firewall-start[391]: iptables v1.8.11 (nf_tables): TABLE_ADD failed (Operation not supported): table filter
Jan 12 16:55:18 nixos systemd[1]: firewall.service: Main process exited, code=exited, status=4/NOPERMISSION
Jan 12 16:55:18 nixos systemd[1]: firewall.service: Failed with result 'exit-code'.
Some diagnostic info:
uname -a
Linux nixos 6.19.0-rc7 SMP PREEMPT_DYNAMIC
[@nixos:~]$ zcat /proc/config.gz | egrep 'NETFILTER|NF_TABLES|XT_|CONNTRACK'
CONFIG_CONTEXT_TRACKING=y
CONFIG_CONTEXT_TRACKING_IDLE=y
CONFIG_HAVE_CONTEXT_TRACKING_USER=y
CONFIG_HAVE_CONTEXT_TRACKING_USER_OFFSTACK=y
CONFIG_NETFILTER=y
CONFIG_NETFILTER_ADVANCED=y
# CONFIG_BRIDGE_NETFILTER is not set
CONFIG_NETFILTER_INGRESS=y
CONFIG_NETFILTER_EGRESS=y
CONFIG_NETFILTER_SKIP_EGRESS=y
CONFIG_NETFILTER_NETLINK=y
CONFIG_NETFILTER_BPF_LINK=y
# CONFIG_NETFILTER_NETLINK_HOOK is not set
# CONFIG_NETFILTER_NETLINK_ACCT is not set
# CONFIG_NETFILTER_NETLINK_QUEUE is not set
CONFIG_NETFILTER_NETLINK_LOG=y
# CONFIG_NETFILTER_NETLINK_OSF is not set
CONFIG_NF_CONNTRACK=y
# CONFIG_NF_CONNTRACK_MARK is not set
CONFIG_NF_CONNTRACK_SECMARK=y
# CONFIG_NF_CONNTRACK_ZONES is not set
CONFIG_NF_CONNTRACK_PROCFS=y
# CONFIG_NF_CONNTRACK_EVENTS is not set
# CONFIG_NF_CONNTRACK_TIMEOUT is not set
# CONFIG_NF_CONNTRACK_TIMESTAMP is not set
# CONFIG_NF_CONNTRACK_LABELS is not set
# CONFIG_NF_CONNTRACK_AMANDA is not set
CONFIG_NF_CONNTRACK_FTP=y
# CONFIG_NF_CONNTRACK_H323 is not set
CONFIG_NF_CONNTRACK_IRC=y
CONFIG_NF_CONNTRACK_BROADCAST=m
CONFIG_NF_CONNTRACK_NETBIOS_NS=m
# CONFIG_NF_CONNTRACK_SNMP is not set
# CONFIG_NF_CONNTRACK_PPTP is not set
# CONFIG_NF_CONNTRACK_SANE is not set
CONFIG_NF_CONNTRACK_SIP=y
# CONFIG_NF_CONNTRACK_TFTP is not set
# CONFIG_NETFILTER_NETLINK_GLUE_CT is not set
CONFIG_NF_TABLES=y
CONFIG_NF_TABLES_INET=y
CONFIG_NF_TABLES_NETDEV=y
CONFIG_NETFILTER_XTABLES=y
CONFIG_NETFILTER_XTABLES_COMPAT=y
CONFIG_NETFILTER_XTABLES_LEGACY=y
CONFIG_NETFILTER_XT_MARK=m
# CONFIG_NETFILTER_XT_CONNMARK is not set
# CONFIG_NETFILTER_XT_TARGET_AUDIT is not set
# CONFIG_NETFILTER_XT_TARGET_CHECKSUM is not set
# CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set
# CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set
CONFIG_NETFILTER_XT_TARGET_CONNSECMARK=y
# CONFIG_NETFILTER_XT_TARGET_DSCP is not set
# CONFIG_NETFILTER_XT_TARGET_HL is not set
# CONFIG_NETFILTER_XT_TARGET_HMARK is not set
# CONFIG_NETFILTER_XT_TARGET_IDLETIMER is not set
# CONFIG_NETFILTER_XT_TARGET_LED is not set
CONFIG_NETFILTER_XT_TARGET_LOG=m
# CONFIG_NETFILTER_XT_TARGET_MARK is not set
CONFIG_NETFILTER_XT_NAT=m
# CONFIG_NETFILTER_XT_TARGET_NETMAP is not set
CONFIG_NETFILTER_XT_TARGET_NFLOG=y
# CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set
# CONFIG_NETFILTER_XT_TARGET_RATEEST is not set
# CONFIG_NETFILTER_XT_TARGET_REDIRECT is not set
CONFIG_NETFILTER_XT_TARGET_MASQUERADE=m
# CONFIG_NETFILTER_XT_TARGET_TEE is not set
# CONFIG_NETFILTER_XT_TARGET_TPROXY is not set
CONFIG_NETFILTER_XT_TARGET_SECMARK=y
CONFIG_NETFILTER_XT_TARGET_TCPMSS=y
# CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP is not set
CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
# CONFIG_NETFILTER_XT_MATCH_BPF is not set
# CONFIG_NETFILTER_XT_MATCH_CGROUP is not set
# CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set
# CONFIG_NETFILTER_XT_MATCH_COMMENT is not set
# CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set
# CONFIG_NETFILTER_XT_MATCH_CONNLABEL is not set
# CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set
# CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=y
# CONFIG_NETFILTER_XT_MATCH_CPU is not set
# CONFIG_NETFILTER_XT_MATCH_DCCP is not set
# CONFIG_NETFILTER_XT_MATCH_DEVGROUP is not set
# CONFIG_NETFILTER_XT_MATCH_DSCP is not set
# CONFIG_NETFILTER_XT_MATCH_ECN is not set
# CONFIG_NETFILTER_XT_MATCH_ESP is not set
# CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set
# CONFIG_NETFILTER_XT_MATCH_HELPER is not set
# CONFIG_NETFILTER_XT_MATCH_HL is not set
# CONFIG_NETFILTER_XT_MATCH_IPCOMP is not set
# CONFIG_NETFILTER_XT_MATCH_IPRANGE is not set
# CONFIG_NETFILTER_XT_MATCH_L2TP is not set
# CONFIG_NETFILTER_XT_MATCH_LENGTH is not set
# CONFIG_NETFILTER_XT_MATCH_LIMIT is not set
# CONFIG_NETFILTER_XT_MATCH_MAC is not set
# CONFIG_NETFILTER_XT_MATCH_MARK is not set
# CONFIG_NETFILTER_XT_MATCH_MULTIPORT is not set
# CONFIG_NETFILTER_XT_MATCH_NFACCT is not set
# CONFIG_NETFILTER_XT_MATCH_OSF is not set
# CONFIG_NETFILTER_XT_MATCH_OWNER is not set
CONFIG_NETFILTER_XT_MATCH_POLICY=y
# CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set
# CONFIG_NETFILTER_XT_MATCH_QUOTA is not set
# CONFIG_NETFILTER_XT_MATCH_RATEEST is not set
# CONFIG_NETFILTER_XT_MATCH_REALM is not set
# CONFIG_NETFILTER_XT_MATCH_RECENT is not set
# CONFIG_NETFILTER_XT_MATCH_SCTP is not set
# CONFIG_NETFILTER_XT_MATCH_SOCKET is not set
CONFIG_NETFILTER_XT_MATCH_STATE=y
# CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set
# CONFIG_NETFILTER_XT_MATCH_STRING is not set
# CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set
# CONFIG_NETFILTER_XT_MATCH_TIME is not set
# CONFIG_NETFILTER_XT_MATCH_U32 is not set
CONFIG_NF_TABLES_IPV4=y
# CONFIG_NF_TABLES_ARP is not set
CONFIG_NF_TABLES_IPV6=y
# CONFIG_NF_TABLES_BRIDGE is not set
# CONFIG_NF_CONNTRACK_BRIDGE is not set
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
# CONFIG_LXT_PHY is not set
# CONFIG_SENSORS_NZXT_KRAKEN2 is not set
# CONFIG_SENSORS_NZXT_KRAKEN3 is not set
# CONFIG_SENSORS_NZXT_SMART2 is not set
CONFIG_CONTEXT_SWITCH_TRACER=y
[@nixos:~]$ zcat /proc/config.gz | grep NF_TABLES_
Would appreciate any pointers to resolve this issue (missing kernel flags?) and/or configuration.nix modification(s) necessary to bring in the firewall at boot.
Thank you.
