Dank Material Shell programs.quickshell does not exist
I’m trying to install dank material shell with home manager and seem to be running into a problem where ‘home-manager.users.user.programs.quickshell does not exist’
Here is my flake
  description = "Flake for my machines";
    nixpkgs.url = "nixpkgs/nixos-25.05";
    nixpkgs-unstable.url = "nixpkgs/nixos-unstable";
    nvf = {
      url = "github:notashelf/nvf";
    hyprland = {
      url = "github:hyprwm/Hyprland";
      inputs.nixpkgs.follows = "nixpkgs-unstable";
    nixcord = {
      url = "github:kaylorben/nixcord";
    sops-nix = {
      url = "github:mic92/sops-nix";
    dgop = {
      url = "github:AvengeMedia/dgop";
    dms-cli = {
      url = "github:AvengeMedia/danklinux";
    dankMaterialShell = {
      url = "github:AvengeMedia/DankMaterialShell";
      inputs.dgop.follows = "dgop";
      inputs.dms-cli.follows = "dms-cli";
    niri = {
      url = "github:sodiboo/niri-flake";
    home-manager = {
      url = "github:nix-community/home-manager/release-25.05";
  outputs = inputs @ {nixpkgs, ...}: {
    nixosConfigurations = {
      majula = nixpkgs.lib.nixosSystem {
        system = "x86_64-linux";
        modules = [
            _module.args = {inherit inputs;};
          ./hosts/majula/configuration.nix
          inputs.home-manager.nixosModules.home-manager
            home-manager = {
              useGlobalPkgs = true;
              useUserPackages = true;
              users.alec = import ./hosts/majula/home.nix;
              backupFileExtension = "backup";
              extraSpecialArgs = {inherit inputs;};
      installerIso = nixpkgs.lib.nixosSystem {
        specialArgs = {inherit inputs;};
        modules = [
          ./hosts/isoImage/configuration.nix
Here is the module for dms
  pkgs,
  config,
  inputs,
  imports = [
    inputs.dankMaterialShell.homeModules.dankMaterialShell.default
    inputs.dankMaterialShell.homeModules.dankMaterialShell.niri
  programs.dankMaterialShell = {
My home.nix
  config,
  pkgs,
  inputs,
  imports = [
    ../../home/programs/git
    ../../home/programs/kitty
    ../../home/programs/shell
    ../../home/programs/nvf
    ../../home/programs/discord
    ../../home/system/dms
    ../../home/system/hyprland
    ../../home/system/niri
    #    ../../home/system/vicinae
    ./variables.nix
    ./secrets
  home.username = "alec";
  home.homeDirectory = "/home/alec";
  home.stateVersion = "25.05";
  home.packages = [
And the error
error:
         at /nix/store/d7s7pkgp0shkac0qwf2f9w956fi6rh1i-source/lib/attrsets.nix:1571:13:
         1570|           if length values == 1 || pred here (elemAt values 1) (head values) then
         1571|             head values
         1572|           else
         at /nix/store/d7s7pkgp0shkac0qwf2f9w956fi6rh1i-source/lib/modules.nix:1083:7:
         1082|     // {
         1083|       value = addErrorContext "while evaluating the option `${showOption loc}':" value;
         1084|       inherit (res.defsFinal') highestPrio;
       … while evaluating the option `system.build.toplevel':
       … while evaluating definitions from `/nix/store/d7s7pkgp0shkac0qwf2f9w956fi6rh1i-source/nixos/modules/system/activation/top-level.nix':
       … while evaluating the option `assertions':
       … while evaluating definitions from `/nix/store/a4la088hi5id7sw77gy9zdvwn83dgczz-source/nixos/common.nix':
       error: The option `home-manager.users.alec.programs.quickshell' does not exist. Definition values:
       - In `/nix/store/hq8d6xbl99vbviyfyjny4sjfzxpi00j4-source/nix/default.nix'
I am still new to Nix and NixOS so any help would be greatly appreciated. Thank you.
Did you import DMS file into an instead of system? Your error is about modules cannot find home-manager options
It wasnt anything involving the imports. To get the error to clear I had to change my home manager version to the unstable branch due to quickshell not being in the 25.05 branch.
Now though im getting a new error
error:
         at /nix/store/58hq018zklzi0jyjfks7g4q02bckvp7j-source/lib/attrsets.nix:1571:13:
         1571|             head values
         1572|           else
         at /nix/store/58hq018zklzi0jyjfks7g4q02bckvp7j-source/lib/modules.nix:1083:7:
         1082|     // {
       … while evaluating definitions from `/nix/store/58hq018zklzi0jyjfks7g4q02bckvp7j-source/nixos/modules/system/activation/top-level.nix':
       … while evaluating the option `warnings':
       … while evaluating definitions from `/nix/store/58hq018zklzi0jyjfks7g4q02bckvp7j-source/nixos/modules/system/boot/systemd.nix':
       … while evaluating the option `systemd.services.home-manager-alec.serviceConfig':
       … while evaluating definitions from `/nix/store/ijblcn7dhnzaqvz1panymwmwz72dnpki-source/nixos':
       … while evaluating the option `home-manager.users.alec.home.file.".manpath".source':
       … while evaluating definitions from `/nix/store/ijblcn7dhnzaqvz1panymwmwz72dnpki-source/modules/files.nix':
       … while evaluating the option `home-manager.users.alec.home.file.".manpath".text':
       … while evaluating definitions from `/nix/store/ijblcn7dhnzaqvz1panymwmwz72dnpki-source/modules/programs/man.nix':
       … while evaluating the option `home-manager.users.alec.home.packages':
       … while evaluating definitions from `/nix/store/ijblcn7dhnzaqvz1panymwmwz72dnpki-source/modules/programs/quickshell.nix':
       … while evaluating the option `home-manager.users.alec.programs.quickshell.package':
       … while evaluating definitions from `/nix/store/yzj5fww60y4xj7wplarqmqqfm2bn16nd-source/nix/default.nix':
       … while evaluating the option `home-manager.users.alec.programs.dankMaterialShell.quickshell.package':
       error: quickshell cannot be found in pkgs
Your configuration is built off of the stable Nixpkgs revision, pkgs in the module system does not have quickshell. Change programs.quickshell.package = pkgs-unstable.quickshell or something.
Here is the final working flake and dms/default.nix file. Home.nix mostly remained unchanged.
    nvf = {
    hyprland = {
    nixcord = {
    sops-nix = {
    dgop = {
    dms-cli = {
    niri = {
    home-manager = {
    nixpkgs,
    nixpkgs-unstable,
        modules = [
            home-manager = {
                inherit inputs;
                pkgs-unstable = import nixpkgs-unstable {
                  config.allowUnfree = true;
        modules = [
  pkgs,
  pkgs-unstable,
  config,
  inputs,
  imports = [
    quickshell.package = pkgs-unstable.quickshell;
