When I run darwin-rebuild switch --flake my home-manager bash settings aren’t applied to my ~/.bashrc, and I am dumped into /bin/bash, not my user shell.
I have tried running /etc/profiles/per-user/holdenc/bin/bash, and source ~/.bashrc, neither result in my expected shell.
When I installed Darwin I used sudo, because I was running into permission issues. I wonder if that might be causing the issue.
I have the following settings in my configuration.nix:
# A list of permissable shells for login accounts
environment.shells = [ pkgs.bashInteractive ];
# enable bash as an interactive shell
programs.bash.enable = true;
# the users's default shell
users.knownUsers = [ "holdenc" ];
users.users.archie = {
home = "/Users/holdenc";
shell = pkgs.bashInteractive;
uid = 501;
Can anyone provide with me with any debugging steps I can try?
Tried nix-collect-garbage -d, rm -rf ~/.cache/nix.
WHere have you set home.programs.bash.enable ? Your config shows nix-darwin set up but no home manager settings, the latter are the ones that affect the files in your home directory.
As for why /bin/bash - I think you have to set your shell in System Settings manually - or set in in your terminal app.
