Does anyone have Davinci Resolve working with rocm on NixOS Unstable or channel 25.05 or later?
In 25.05 rocmPackages_5 were removed. I pinned rocmPackages_5.clr from channel 24.11, but still have crashes at launch.
With rocm 6 DR initialization completes and crashes when opening a project, with logs complaining about DR unable to find rocm 5.
rocm 5 package pin logs
0x7f2bbf500000 | Main | INFO | 2025-11-19 13:17:02,802 | Running DaVinci Resolve Studio v20.2.3.0006 (Linux/Clang x86_64)
0x7f2bbf500000 | Main | INFO | 2025-11-19 13:17:02,802 | BMD_BUILD_UUID 924275c8-3ec6-42e9-a84a-def97e8e5c18
0x7f2bbf500000 | Main | INFO | 2025-11-19 13:17:02,802 | BMD_GIT_COMMIT 14afe2c9cac879ba880bb57b3d6987912c4679c4
0x7f2bbf500000 | GPUDetect | INFO | 2025-11-19 13:17:02,802 | Starting GPUDetect 1.2_9-a4
0x7f2bbf500000 | GPUDetect | INFO | 2025-11-19 13:17:02,854 | Done in 51 ms.
0x7f2bbf500000 | GPUDetect | INFO | 2025-11-19 13:17:02,854 | Detected System:
0x7f2bbf500000 | GPUDetect | INFO | 2025-11-19 13:17:02,854 | - OS: Linux NixOS 25.11 (Xantusia)
0x7f2bbf500000 | GPUDetect | INFO | 2025-11-19 13:17:02,854 | - Model: Valve Jupiter
0x7f2bbf500000 | GPUDetect | INFO | 2025-11-19 13:17:02,854 | - System ID: e401b9bee7424a00aa77bbc2be6ba8c6
0x7f2bbf500000 | GPUDetect | INFO | 2025-11-19 13:17:02,854 | - CPU: AMD Custom APU 0405, 8 threads, x86-64
0x7f2bbf500000 | GPUDetect | INFO | 2025-11-19 13:17:02,854 | - RAM: 6.2 GiB used of 13.5 GiB
0x7f2bbf500000 | GPUDetect | INFO | 2025-11-19 13:17:02,854 | Detected 1 GPUs:
0x7f2bbf500000 | GPUDetect | INFO | 2025-11-19 13:17:02,854 | - “AMD Custom GPU 0405” (gpu:181b4f18.7869974b) ← Main Display GPU
0x7f2bbf500000 | GPUDetect | INFO | 2025-11-19 13:17:02,854 | Discrete, 161 MiB used of 6.7 GiB VRAM, PCI:4:0.0
0x7f2bbf500000 | GPUDetect | INFO | 2025-11-19 13:17:02,854 | Matches: OpenCL, XOrg
0x7f2bbf500000 | GPUDetect | INFO | 2025-11-19 13:17:02,854 | Detected 1 monitors:
0x7f2bbf500000 | Main.GPUConfig | INFO | 2025-11-19 13:17:02,854 | Compute API set to automatic, defaulting to OpenCL.
0x7f2bbf500000 | Main.GPUConfig | INFO | 2025-11-19 13:17:02,854 | Selected compute API: OpenCL
0x7f2bbf500000 | Main.GPUConfig | INFO | 2025-11-19 13:17:02,854 | Manual GPU Selection:
0x7f2bbf500000 | Main.GPUConfig | INFO | 2025-11-19 13:17:02,854 | - “AMD Custom GPU 0405” (gpu:181b4f18.7869974b)
0x7f2bbf500000 | IO | INFO | 2025-11-19 13:17:02,854 | RED InitializeSdk with library path at /nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/libs
0x7f2bbf500000 | IO | INFO | 2025-11-19 13:17:02,896 | R3DAPI 9.1.1-57f6471 (20251008 Lx64S OpenCL-Fix) R3DSDK 9.1.1-57f6471 (20251008 Lx64D C3B3 OpenCL-Fix) RED OPENCL 9.1.2-0 (20251008) [/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/libs/] init is successful
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
0x7f2bbf500000 | Main | INFO | 2025-11-19 13:17:02,896 | Decklink model name: ‘’, version: ‘’
0x7f2bbf500000 | DVIP | INFO | 2025-11-19 13:17:02,896 | DVIP release/20.2.3 build 5 (2911bb7349f9231d95027cde33a677d4ef47b576). Release, version 20.2.3.
0x7f2a605ea000 | IO | INFO | 2025-11-19 13:17:03,031 | Using DNxHR library v3.0.0.1312r
0x7f2a60deb000 | Fusion | INFO | 2025-11-19 13:17:03,167 | Fusion Build: 45bdfb5a_0006 (Nov 3 2025 06:57:56)
0x7f2a4bbf3000 | Fusion | INFO | 2025-11-19 13:17:03,170 | fusionsystem: = “/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/libs/Fusion/libfusionsystem.so”
0x7f2a605ea000 | IO | INFO | 2025-11-19 13:17:03,171 | Initialized ARRIImageSDK version 9.0.0
0x7f2a605ea000 | IO | INFO | 2025-11-19 13:17:03,171 | Apple ProRes RAW plugin - Standard v1.3 [com.apple.proresraw.prrplugin.standardrawconversion]
0x7f2a605ea000 | IO | INFO | 2025-11-19 13:17:03,171 | Found 1 Apple ProRes RAW plugins.
0x7f2a605ea000 | IO | ERROR | 2025-11-19 13:17:03,171 | ProRes RAW SDK raw conversion plug-in loading error(s): unable to open default plug-in directory /usr/local/lib/proresraw/plugins
0x7f2a605ea000 | IO | INFO | 2025-11-19 13:17:03,171 | IO codec library load completed in 140 ms.
0x7f2a4bbf3000 | Fusion | INFO | 2025-11-19 13:17:03,175 | FusionLibs: = “/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/libs/Fusion/”
0x7f2a4bbf3000 | Fusion | INFO | 2025-11-19 13:17:03,175 | UserData: = “/home/sk4g/.local/share/DaVinciResolve/Fusion”
0x7f2a4bbf3000 | Fusion | INFO | 2025-11-19 13:17:03,175 | Profiles: = “UserData:Profiles/”
0x7f2bbf500000 | UI | INFO | 2025-11-19 13:17:03,189 | UI language is set to “Auto”, and system language is “en”.
Attribute Qt::AA_ShareOpenGLContexts must be set before QCoreApplication is created.
0x7f2a451f9000 | DbCommon2 | INFO | 2025-11-19 13:17:03,191 | Loading dblist file: /home/sk4g/.local/share/DaVinciResolve/configs/.dblist
0x7f2bbf500000 | Main | INFO | 2025-11-19 13:17:03,238 | Finished loading Application style sheet
0x7f2bbf500000 | Main | INFO | 2025-11-19 13:17:03,258 | Show splash screen
0x7f2bbf500000 | Main | INFO | 2025-11-19 13:17:03,258 | Show splash screen message: Starting Up
qt.glx: qglx_findConfig: Failed to finding matching FBConfig for QSurfaceFormat(version 4.5, options QFlagsQSurfaceFormat::FormatOption(DeprecatedFunctions), depthBufferSize -1, redBufferSize 1, greenBufferSize 1, blueBufferSize 1, alphaBufferSize 0, stencilBufferSize -1, samples -1, swapBehavior QSurfaceFormat::SingleBuffer, swapMethod 0, swapInterval 1, colorSpace QSurfaceFormat::DefaultColorSpace, profile QSurfaceFormat::CoreProfile)
No XVisualInfo for format QSurfaceFormat(version 4.5, options QFlagsQSurfaceFormat::FormatOption(DeprecatedFunctions), depthBufferSize -1, redBufferSize 1, greenBufferSize 1, blueBufferSize 1, alphaBufferSize 0, stencilBufferSize -1, samples -1, swapBehavior QSurfaceFormat::SingleBuffer, swapMethod 0, swapInterval 1, colorSpace QSurfaceFormat::DefaultColorSpace, profile QSurfaceFormat::CoreProfile)
Falling back to using screens root_visual.
0x7f2a3b997000 | Main | INFO | 2025-11-19 13:17:03,856 | Started listener socket at port 15000
libScannerAPI.so: cannot open shared object file: No such file or directory
0x7f2bbf500000 | Main | INFO | 2025-11-19 13:17:03,857 | Application state changed to Active
qt.glx: qglx_findConfig: Failed to finding matching FBConfig for QSurfaceFormat(version 4.5, options QFlagsQSurfaceFormat::FormatOption(DeprecatedFunctions), depthBufferSize -1, redBufferSize 1, greenBufferSize 1, blueBufferSize 1, alphaBufferSize -1, stencilBufferSize -1, samples -1, swapBehavior QSurfaceFormat::SingleBuffer, swapMethod 0, swapInterval 1, colorSpace QSurfaceFormat::DefaultColorSpace, profile QSurfaceFormat::CoreProfile)
Could not initialize GLX
==========[CRASH DUMP]==========
#TIME Wed Nov 19 13:17:04 2025 - Uptime 00:00:00 (hh:mm:ss)
#PROGRAM_NAME DaVinci Resolve Studio v20.2.3.0006 (Linux/Clang x86_64)
#BMD_ARCHITECTURE x86_64
#BMD_BUILD_UUID 924275c8-3ec6-42e9-a84a-def97e8e5c18
#BMD_GIT_COMMIT 14afe2c9cac879ba880bb57b3d6987912c4679c4
#BMD_UTIL_VERSION 20.2.3.0006
#OS Linux
/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/bin/resolve() [0x6008129]
/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/bin/resolve() [0x60072f2]
/usr/lib/libc.so.6(+0x419c0) [0x7f2bb28419c0]
/usr/lib/libc.so.6(+0x9caac) [0x7f2bb289caac]
/usr/lib/libc.so.6(gsignal+0x1e) [0x7f2bb284190e]
/usr/lib/libc.so.6(abort+0xdf) [0x7f2bb2828942]
/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/libs/libQt5Core.so.5(+0x1821c6) [0x7f2bb49821c6]
/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/libs/libQt5Core.so.5(_ZNK14QMessageLogger5fatalEPKcz+0xbd) [0x7f2bb496ea5d]
/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/libs/plugins/xcbglintegrations/libqxcb-glx-integration.so(+0xb5bb) [0x7f2bb89f65bb]
/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/libs/plugins/xcbglintegrations/libqxcb-glx-integration.so(+0x9b28) [0x7f2bb89f4b28]
/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/libs/plugins/xcbglintegrations/libqxcb-glx-integration.so(+0x941d) [0x7f2bb89f441d]
/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/libs/libQt5Gui.so.5(_ZN14QOpenGLContext6createEv+0x34) [0x7f2bb6f62e44]
/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/bin/resolve() [0x385d8b3]
/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/bin/resolve() [0x350e718]
/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/bin/resolve() [0x350d2f4]
/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/bin/resolve() [0x35061ca]
/usr/lib/libc.so.6(+0x2a4d8) [0x7f2bb282a4d8]
/usr/lib/libc.so.6(__libc_start_main+0x8b) [0x7f2bb282a59b]
/nix/store/k2agn8ahpgxip4dyrnqby98apvxp74bf-davinci-resolve-studio-20.2.3/bin/resolve() [0x350464e]
Signal Number = 6
