prologue: Hi, I’m new to the discussion forums, not sure this is the right board/space for this, sorry if I’ve committed “cardinal-sin”
Pre-RFC: Decoupling build-support into a Deferred Higher-Order Function Library (PkgsLib)
Abstract
This RFC proposes a structural and architectural shift in how Nixpkgs manages its build orchestration tools.
Currently, build-support utilities (e.g., buildGoModule, buildRustPackage, fetchFromGitHub) live within the pkgs attribute set.
In a sense this means we’re treating package blueprints as if they’re packages themselves…
This doesn’t make any sense at all?!; and seems literally like an architectural relic, that came into existence because everyone agreed -
They require packages so… they don’t belong in lib?…
But “not belonging in lib” doesn’t mean they automatically belong in pkgs either. Realistically - build-support functions… function as if they are simply a “second lib”, which “happens to require” a pkgs argument.
So, maybe they should be treated like exactly that.
I propose refactoring build-support into a deferred, higher-order function library. eg: PkgsLib… or similar — and moving it outside the core package instantiation scope.
By passing pkgs as a lazy input argument through a multi-stage evaluation pipeline, we get strict conceptual alignment, eliminate core infinite recursion risks, and optimize evaluation latency.
Feel free to add to the case for a change like this + inform me of anything incorrect/stupid, and how it could be made less stupid.
Also, feel free to check out/add to this/these repo(s).
A centralized repo for “developing” the idea, where we can draw out the issues, ideas, etc. from any discussions; and you could help make this into an Actual RFC.
The repo where I’m working on extensions to a few build-support functions, which might be pulled into/become a future proof of concept repo, when finished
1. Motivation & Conceptual Misalignment
In the current Nixpkgs architecture, the boundary between lib and pkgs is defined - operationalized by system dependence:
libcontains pure, system-agnostic utility functions (logic).pkgscontains platform-dependent derivations (software).
Because build-support functions require compilers, linkers, and fetchers, they are deeply system-dependent and are forced to reside inside pkgs.
However, this introduces a deep conceptual flaw: builders are not packages; they are higher-order functions that output package recipes.
Treating builders as standard attributes inside a mutually recursive package set creates two core problems:
The Bootstrap Catch-22:
Fetchers and basic builders frequently cause infinite recursion loops if a downstream package override accidentally alters an upstream dependency used by the builder itself.
Monolithic Evaluation Overhead:
Because builders are bound directly inside the massive pkgs fixpoint loop, decoupling structural build logic from concrete software compilation is incredibly difficult, impeding tree-wide optimization and modularity.
Silent Failures in Standard Nixpkgs:
Currently in Nixpkgs, functions like .overrideAttrs take an arbitrary, unchecked attribute set. If you make a typo in a dependency or a build flag name, Nix will not throw an error. It will silently ignore the typo, drops your configuration, and builds the wrong binary.
This fixes that… because the builder functions would be moved into a “deferred library”, they become what they have always been… **functions**.
Meaning all packages become modules
This pattern completely replaces fragile functional overrides (.override), with a type-checked, mergeable, and modular schema.
- You Gain type checking/type safety
- The Module System catches the Error
- You enforce a strict schema.
- If a user inputs an unrecognized variable name, when defining a package the evaluation immediately (and correctly) crashes with a clear traceback.
2. Proposed Architecture
I propose introducing an explicit/linear three-stage evaluation pipeline that separates pure tool bootstrapping, deferred build logic, and final package materialization.
Stage 0: The Immutable Bootstrap Layer
A minimal, raw set of primitive derivations (e.g., standard stdenv, bash, curl) is evaluated immediately. This layer is entirely locked down and cannot accept downstream overrides.
Stage 1: The PkgsLib Scope
build-support is converted into a library of partially applied functions or deferred modules.
- Primitive actions (like
fetchgit) pull their execution tools strictly from Stage 0. - High-level abstractions (like
buildGoModule) accept the final package set (finalPkgs) as a lazy, late-bound argument to reference target compilers.
Stage 2: Final Resolution Loop (pkgs)
Using an open fixpoint (lib.fix), the final user-facing package set is materialized by feeding the instantiated pkgs back into PkgsLib.
Architectural Deep-Dive: Mechanics and Benefits
1. Passing pkgs as a Lazy Input Argument
Mechanism:
Instead of nesting builders directly inside the global package scope, PkgsLib is structured as a deferred function: makePkgsLib = finalPkgs: { … }.
Effect:
This introduces a “late binding” phase.
The blueprint logic for a builder sits entirely dormant in memory.
It does not look for compilers, libraries, or dependencies until a fully instantiated pkgs object is explicitly passed to it at the final step of evaluation.
2. Philosophical/Conceptual Alignment
The Mechanism:
build-support is removed from the pkgs attribute set and structurally relocated into its own functional layer.
The Impact:
This fixes a fundamental category error.
In current Nixpkgs…
pkgs.buildGoModule
(a function requiring pkgs) is structurally handled the exact same way as pkgs.hello
(a discrete derivation).
Relocating it, and other builders… to a dedicated library ensures the code structure reflects reality:
Builders are an engineering library of functions, not compiled software artifacts.
3. Eliminating Core Infinite Recursion Risks
- The Mechanism: The multi-stage pipeline establishes a strict, one-way dependency boundary between the bootstrap layer (
Stage 0) and the finalized packages (Stage 2). - The Impact: This completely isolates a major vector for evaluation failures.
- The Status Quo: If a user writes an override to patch
curlglobally,fetchgitimmediately tries to use that patchedcurl. If building that patchedcurlrequires fetching a source code repository viafetchgit, evaluation crashes with an infinite recursion error. - The New Pipeline: The
fetchgitbuilder insideStage 1is strictly pinned tobootstrapPkgs.curlfromStage 0. Downstream package overrides inStage 2cannot cross the boundary to reach backward intoStage 0.fetchgitsafely fetches the source using the immutable bootstrap tools, breaking the recursive loop entirely.
4. Optimizing Evaluation Latency
- The Mechanism: This leverages Nix’s native lazy evaluation model by separating structural abstractions from concrete values.
- The Impact: In standard Nixpkgs, because builders are tightly coupled to the global recursive fixpoint, the evaluator must frequently wade through complex package dependency trees just to resolve a builder’s environment. Moving builders to a pure function layer creates a radical shortcut: the evaluator processes the builder logic instantaneously, deferring heavy package compilation logic until the exact moment a specific attribute path is built.
3. Conceptual Implementation Example
Straight-up vibe-coded/probably trash - aside from illustrating the concept; to get the idea out faster
lib = import <nixpkgs/lib>;
# STAGE 0: Isolated Bootstrap Tools
## Evaluates immediately. These are pinned and completely immune to downstream overrides,
## breaking the primary vector for infinite recursion in standard fetchers.
## evaluating only up to the point that we have a barebones coreutils+minimalCurl+stdenv (bound to system), basically running the stage0/hex0/mesC up to coreutils build process
bootstrapPkgs = {
stdenv = { /* primitive stdenv */ };
curl = { /* primitive curl */ };
coreutils = { /* primitive coreutils */ };
# STAGE 1: PkgsLib (Deferred Higher-Order Builders Library)
# A decoupled logic layer. It takes finalPkgs as a late-bound argument.
# Fetchers pin strictly to Stage 0 tools to ensure absolute purity and stability
fetchgit = { url, sha256 }: bootstrapPkgs.stdenv.mkDerivation {
name = "source";
buildInputs = [ bootstrapPkgs.curl ];
# ... fetch logic
# Ecosystem builders defer compiler selection to finalPkgs, allowing for dynamic overrides
buildGoModule = { src, ... }@args: bootstrapPkgs.stdenv.mkDerivation (args // {
buildInputs = [ finalPkgs.go ] ++ (args.buildInputs or []);
# STAGE 2: Reconstructed Materialized Packages
# The final open fixpoint loop where the user-facing package set is constructed.
pkgs = lib.fix (finalPkgs:
pkgsLib = makePkgsLib finalPkgs;
# Compilers live safely inside the final tier
go = bootstrapPkgs.stdenv.mkDerivation { /* go compiler recipe */ };
# Packages call upon the deferred library, passing inputs down cleanly
myGoApp = pkgsLib.buildGoModule {
pname = "app";
version = "1.0";
src = pkgsLib.fetchgit { url = "https://github.com"; sha256 = "..."; };
pkgs.myGoApp
4. Key Advantages
A. Total Elimination of Circular Bootstrapping
By forcing a strict downward data flow
Stage 0 (lib)
Stage 1 (+ "PkgsLib" + "bootstrap compilers")
Stage 2 (+ stdenv + generic pkg-expressions)
A primitive tool like fetchgit will never query finalPkgs for its environment. This effectively patches an entire class of infinite recursion bugs that plague complex package overrides.
B. Perfect Laziness and Memory Optimization
Because the structural rules of PkgsLib are separated from package instantiation, Nix’s lazy evaluation engine shines. No package derivation or compiler blueprint is evaluated until its specific attribute path is explicitly invoked.
C. Tree-wide Customization without Global Rebuilds
Downstream users can safely swap out compilers or flags inside finalPkgs without accidentally mutating the underlying fetching or building framework mechanics, enabling clean ecosystem testing.
5. Community Proofs of Concept: dream2nix, devenv, flake-parts
Because modifying the main Nixpkgs repository requires navigating massive legacy compatibility constraints, developers have built greenfield projects to prove that your proposed layout works flawlessly at scale.
dream2nix:
This project completely reimagines packaging by turning builders (buildGoModule, buildRustPackage) into modular, discrete plug-ins.
It handles package constraints almost exactly like this PkgsLib pipeline: it passes an instantiated pkgs attribute set downstream into structural module blueprints.
devenv and flake-parts
These systems heavily rely on specialArgs and deferred module functions to safely pass things like the system tuple (x86_64-linux) or pkgs downstream only when needed.
6. Drawbacks and Implementation Challenges
- Refactoring Effort: Transitioning the entire Nixpkgs tree away from
pkgs.buildGoModuleto a decoupled structure represents a colossal breaking change. - Compatibility Layer Required: A backwards-compatible shim would be mandatory, mapping
pkgs.buildGoModuleback topkgsLib.buildGoModuleso that existing user expressions do not break. - Evaluation Performance Tuning: While lazy evaluation is protected, managing large-scale fixpoint injection across 80,000+ packages would have to be benchmarked to ensure the Nix evaluator does not suffer from excessive memory overhead.
