DeltaNAR - Delta based deployment tool for Nix
Introduction
Nix deployments can be very bandwidth-intensive, and in certain deployments such as spacecraft or other very remote systems this can become a major hurdle.
This is the problem DeltaNAR aims to solve.
By computing the delta between the desired deployment state & what already exists in the Nix store on the host we can drastically reduce the bandwidth required to push update closures.
Features
  • Computes deployment deltas using a content-defined chunker, but also with higher levels of deduplication such as file & directory level
  • Deploy either to a remote Nix store using nix-store –import or to a binary cache
Docs
If you want to try this out or want to know more about the internals check out the docs:
Acknowledgements
DeltaNAR is sponsored by OroraTech:rocket:
haven’t had the chance to check yet, but the problem statement also reminds me a bit of qyriad/rfd-modular-dynamicism: An experimental proposal for dynamic configs in NixOS - AFNix
Yay, back to the roots! In the old day where any Hydra failure blocked all binary substitutions, there were also binary deltas offered between consecutive iterations of build-the-world.
More Nix in space! :rocket: :satellite:
Hi @adisbladis , this looks very interesting! May I ask, do you have any benchmarks for how much bandwidth is saved on average for normal operations e.g. bumping a flake lock?
It is of course impossible to say exactly how much deduplication saves as it depends heavily on your particular closures. YMMV.
I’ll use my personal laptops closure for demonstration. This wasn’t just a nixpkgs bump but a bunch of other stuff as well.
All sizes are specified in bytes.
Old closure size: 28476465120
New closure size: 28745549040
Nix path-info delta: 9002791952
Delta computed with DeltaNAR: 3318757951
Compressed DeltaNAR file (default xz params): 905981224
So in this particular instance it’s a ~63% reduction in size compared to what nix copy would have done.
