I’ve been reading manual on how to define NixOS modules, trying to wrap my head around the inner workings of how the system all comes together. As far as I understand, any file I include with the imports statement, as well as my top-level configuration.nix is referred to as a module. The documentation states that modules can contain an options property to declare options (as in: what types they have) and a config section which then defines actual values for these options (which have been declared in other modules).
Here comes my question: how does this config property differ from simply defining values at the top-level? For example, I’m not sure where the difference is between these two modules:
{ config, ... }:
environment.etc.firstfile.text = "hello";
environment.etc.secondfile.text = config.networking.hostName;
{ config, ... }:
config = {
In both cases, I get “hello” in /etc/firstfile and the system’s hostname in /etc/secondfile. If any property that doesn’t have a special meaning gets merged into config anyway, what’s the point of having a special config property? And why do most modules use config instead of directly defining options?
