Difference between `gccgo13` and `gcc13` package?
May I ask what the difference between those two packages is? Both seem to provide the same programs.
greetings !
gcc13 is a GNU Compiler Collection, that mainly includes C/C++ compilers and other tools to deal with binaries eg objcopy objdump ranlib readelf size strings strip
gccgo13 is esentially same as gcc13 but with additionally enabled gccgo compiler
nix-build -A gccgo13
/nix/store/9pw9ih4kw4ac7142bbxdz64f2xw02790-gccgo-wrapper-13.1.0
[kirillvr@tsutenkaku:~/nixpkgs]$ ls result/bin/
addr2line  ar  as  c++  cc  c++filt  cpp  dwp  elfedit  g++  gcc  gccgo  go  gprof  ld  ld.bfd  ld.gold  nm  objcopy  objdump  ranlib  readelf  size  strings  strip
hopefully that clears up the confusion
yes it does! Thank you :grin:
