I’m quite new to the wonderfull nix world and wondering what is the difference between the ‘nix-shell’, ‘nix shell’ and ‘nix develop’ commands.
From what I know, nix-shell is the same as nix shell but older and using nix channels instead of flakes.
In my mind nix shell was the exact same as nix develop in the sense it opens a shell with packages installed as specified in a flake.
I ask because I noticed that nix shell and nix develop commands does not open shells in the same way:
If I lauch for example nix shell nixpkgs#hello, the result is a shell launched with the hello package installed and my actual shell (zsh) still have access to my shell config.
On the other hand, with a small flake like that:
description = "Build Shell with any dependency of the project";
inputs.nixpkgs.url = "github:NixOs/nixpkgs";
flake-utils.lib.eachDefaultSystem
(system:
let pkgs = nixpkgs.legacyPackages.${system};
nativeBuildInputs = [ pkgs.hello];
If I run nix develop in the flake folder, I have also a new shell with the hello package installed but all my config is gone and I’m back with the default bash.
Questions:
- Why is there no trace of my global config with nix develop but not with nix shell ?
- What is the difference between the two ?
- Why the flake I showed before does not work with
nix shell #.?
