- Title
- What happens to files in the FHS-created directories (like
/usr/liband/usr/include) when the FHS environment is exited? - Is there any way I can add something like a shell hook to the returned environment?
What’s the difference between pkgs.buildFHSEnv and pkgs.buildFHSUserEnv?
None, they’re both the same thing, buildFHSUserEnv was renamed to buildFHSEnv in 23.05
What happens to files in the FHS-created directories (like /usr/lib and /usr/include) when the FHS environment is exited?
The FHS is made up of two parts:
- An immutable filesystem, that’s constructed as a derivation, only once. (ex: pkgs.steam.fhsenv)
- A script that enters that environment, using bubblewrap, mounting some directories like
/etc.
So, what happens with the files inside those directories? Nothing, either the filesystem is read-only:
$ steam-run mkdir -p /usr/lib/test
mkdir: cannot create directory ‘/usr/lib/test’: Read-only file system
or it’s mounted somewhere:
$ steam-run sh -c 'echo hi! > ~/test'
$ cat ~/test
hi!
I think you want the profile attribute, the opitons are documented here
