I’m trying to get a local python environment built as a template for future python projects that I might want. Since there is a poetry2nix (and it seems well supported), I thought I would start by trying to get poetry into my environment, and since I’m just learning nix, and flakes are the future, I thought I would try with a flake:
description = "Application packaged using poetry2nix";
inputs.nixpkgs.url = "github:NixOS/nixpkgs/22.05";
inputs.poetry2nix = {
url = "github:nix-community/poetry2nix/1.36.0";
outputs = { self, nixpkgs, flake-utils, poetry2nix }:
# Nixpkgs overlay providing the application
overlay = nixpkgs.lib.composeManyExtensions [
poetry2nix.overlay
(final: prev: {
# The application
myapp = prev.poetry2nix.mkPoetryApplication {
projectDir = ./.;
} // (flake-utils.lib.eachDefaultSystem (system:
pkgs = import nixpkgs {
inherit system;
overlays = [ self.overlay ];
apps = {
myapp = pkgs.myapp;
defaultApp = pkgs.myapp;
devShell = pkgs.mkShell {
buildInputs = with pkgs; [
(python39.withPackages (ps: with ps; [ poetry ]))
It is fairly simple, python 3.9 with poetry (and poetry2nix) from a template I found somewhere, however it fails to build:
❯ nix develop . ~proj/t/local_python_2
error: Package ‘python3.9-pyopenssl-22.0.0’ in /nix/store/di36mqc6y19ivaa4qjrb2l82c6dqg7m3-source/pkgs/development/python-modules/pyopenssl/default.nix:73 is marked as broken, refusing to evaluate.
a) To temporarily allow broken packages, you can use an environment variable
for a single invocation of the nix tools.
$ export NIXPKGS_ALLOW_BROKEN=1
Note: For `nix shell`, `nix build`, `nix develop` or any other Nix 2.4+
(Flake) command, `--impure` must be passed in order to read this
environment variable.
b) For `nixos-rebuild` you can set
{ nixpkgs.config.allowBroken = true; }
in configuration.nix to override this.
c) For `nix-env`, `nix-build`, `nix-shell` or any other Nix command you can add
{ allowBroken = true; }
to ~/.config/nixpkgs/config.nix.
Ok, maybe it is just because 22.05 has some problems, lets replace 22.05 with 21.11 and see if that changes things:
warning: updating lock file '/Users/spott/projects/templates/local_python_nodirenv/flake.lock':
• Updated input 'nixpkgs':
'github:NixOS/nixpkgs/ce6aa13369b667ac2542593170993504932eb836' (2022-05-30)
→ 'github:NixOS/nixpkgs/a7ecde854aee5c4c7cd6177f54a99d2c1ff28a31' (2021-11-30)
error: builder for '/nix/store/s83b0apc094z6qjs249vqb246nd64ksh-python3.9-cheroot-8.5.2.drv' failed with exit code 1;
last 10 log lines:
> warnings.warn(pytest.PytestUnhandledThreadExceptionWarning(msg))
> -- Docs: https://docs.pytest.org/en/stable/warnings.html
> =========================== short test summary info ============================
> FAILED cheroot/test/test_ssl.py::test_ssl_env[VerifyMode.CERT_NONE-False-pyopenssl]
> FAILED cheroot/test/test_ssl.py::test_ssl_env[VerifyMode.CERT_NONE-True-pyopenssl]
> FAILED cheroot/test/test_ssl.py::test_ssl_env[VerifyMode.CERT_OPTIONAL-False-pyopenssl]
> FAILED cheroot/test/test_ssl.py::test_ssl_env[VerifyMode.CERT_OPTIONAL-True-pyopenssl]
> FAILED cheroot/test/test_ssl.py::test_ssl_env[VerifyMode.CERT_REQUIRED-True-pyopenssl]
> ===== 5 failed, 103 passed, 41 deselected, 3 xfailed, 4 warnings in 40.43s =====
For full logs, run 'nix log /nix/store/s83b0apc094z6qjs249vqb246nd64ksh-python3.9-cheroot-8.5.2.drv'.
error: 1 dependencies of derivation '/nix/store/bcq4n3bfpgwffdg5kf70xj8hszqzc938-python3.9-cherrypy-18.6.0.drv' failed to build
error: 1 dependencies of derivation '/nix/store/mpf5iv3y5vc7mvqha6x6f708xykixg5v-python3.9-cachecontrol-0.12.10.drv' failed to build
error: 1 dependencies of derivation '/nix/store/q1gghrjl3a00yj3r007x856bwn00ffpw-python3-3.9.6-env.drv' failed to build
error: 1 dependencies of derivation '/nix/store/hs4d78xqmxn982w9ni95xwhnmrpq28vw-nix-shell-env.drv' failed to build
Ok, that didn’t work… lets try a different template:
description = "My Python application";
nixpkgs.url = "github:NixOS/nixpkgs";
customOverrides = self: super: {
# Overrides go here
app = pkgs.poetry2nix.mkPoetryApplication {
projectDir = ./.;
overrides =
[ pkgs.poetry2nix.defaultPoetryOverrides customOverrides ];
packageName = "test";
packages.${packageName} = app;
#defaultPackage = self.packages.${system}.${packageName};
buildInputs = with pkgs; [ poetry ];
inputsFrom = builtins.attrValues self.packages.${system};
but this just gives:
error: getting status of '/nix/store/nga7hra037ia2mwsglr5dlzyrziz4nhx-source/poetry.lock': No such file or directory
But I don’t have a poetry.lock because I haven’t installed poetry yet!
even a nix-shell -p python39Packages.poetry spits out the can’t find a matching version problem.
But pypi has matching versions that fit the requirment (Links for xattr), and nixpkgs does too: Nix Package Versions (though it seems this requires using a completely different nixpkgs version…)
I finally got this working by doing:
nix-shell -p python39Packages.xattr -I nixpkgs=https://github.com/NixOS/nixpkgs/archive/ee01de29d2f58d56b1be4ae24c24bd91c5380cea.tar.gz python39Packages.poetry
though this uses an older version of poetry (1.1.14).
How am I supposed to be doing this? Is Poetry just broken in nixpkgs-unstable (and 22.05? and 21.11?). does nixpkgs only have 1 version of python packages?
ps: I’ll be honest, I’m running this on an M1 MacBook on Ventura (which came out before 22.05), so maybe it is my machine… though theoretically I can run x86 code, and the system environment shouldn’t matter in nix… that is the whole point, right?
