So, I’m running NixOS Unstable, and I just updated my system for the first time in about a month. Now, it seems that Discord won’t work for me. I have Discord installed via HomeManager like this:
home.packages = with pkgs; [
(discord-canary.override {
withOpenASAR = true;
When I try to run discord via the command line with the executable discordcanary I get the following error message:
LATITUDE-NIXOS ~ » discordcanary
[Nix] Disabling updates already done
[OpenAsar > Init] OpenAsar 0-unstable-2024-09-06
[OpenAsar > Settings] /home/sophia/.config/discordcanary/settings.json {
SKIP_HOST_UPDATE: true,
openasar: { setup: true, quickstart: true, themeSync: false },
chromiumSwitches: {},
IS_MAXIMIZED: false,
IS_MINIMIZED: false,
WINDOW_BOUNDS: { x: 3, y: 37, width: 1920, height: 1046 },
trayBalloonShown: true,
MINIMIZE_TO_TRAY: false,
OPEN_ON_STARTUP: false
[OpenAsar > BuildInfo] { releaseChannel: 'canary', version: '0.0.508' }
[OpenAsar > Modules] Checking
Error: Cannot find module 'discord_desktop_core'
Require stack:
- /nix/store/ragzxqkdfjnyqly0rrqjfmmz4rzz2w0a-discord-canary-0.0.508/opt/DiscordCanary/resources/app.asar/bootstrap.js
- /nix/store/ragzxqkdfjnyqly0rrqjfmmz4rzz2w0a-discord-canary-0.0.508/opt/DiscordCanary/resources/app.asar/index.js
at Module._resolveFilename (node:internal/modules/cjs/loader:1152:15)
at s._resolveFilename (node:electron/js2c/browser_init:2:124611)
at Module._load (node:internal/modules/cjs/loader:993:27)
at c._load (node:electron/js2c/node_init:2:17025)
at Module.require (node:internal/modules/cjs/loader:1240:19)
at require (node:internal/modules/helpers:179:18)
at startCore (/nix/store/ragzxqkdfjnyqly0rrqjfmmz4rzz2w0a-discord-canary-0.0.508/opt/DiscordCanary/resources/app.asar/bootstrap.js:1:1517)
at EventEmitter.<anonymous> (/nix/store/ragzxqkdfjnyqly0rrqjfmmz4rzz2w0a-discord-canary-0.0.508/opt/DiscordCanary/resources/app.asar/bootstrap.js:1:2630)
at Object.onceWrapper (node:events:633:28)
at EventEmitter.emit (node:events:519:28) {
code: 'MODULE_NOT_FOUND',
requireStack: [
'/nix/store/ragzxqkdfjnyqly0rrqjfmmz4rzz2w0a-discord-canary-0.0.508/opt/DiscordCanary/resources/app.asar/bootstrap.js',
'/nix/store/ragzxqkdfjnyqly0rrqjfmmz4rzz2w0a-discord-canary-0.0.508/opt/DiscordCanary/resources/app.asar/index.js',
undefined
} uncaughtException
[OpenAsar > Modules] Update: discord_desktop_core 0 -> 9
[OpenAsar > Modules] Update: discord_utils 0 -> 10
[OpenAsar > Modules] Update: discord_voice 0 -> 11
