Disko won't build swap partition, what am I doing wrong?
I want to setup disko with impermanence. I’ve instaled nixos fresh on a new machine and written a disko config file (below).
As far as I can tell, the disko setup is fine. If I run disko, it doesn’t complain about the syntax or setup (which it did initially, I think I’ve now ironed all of this out) and it runs sgdisk like it should. The first partition is setup fine and I get a message “The operation has completed successfuly” (actually I get two – one for the initial partition table and then another for the first file system, called “1:disk-main-ESP”. Then the next sgdisk invocation happens, to create the swap parition, and I get a serious of error messages and then a similar invocation which also fails:
+ sgdisk --align-end --new=2:1G:9G --change-name=2:disk-main-swap --typecode=2:8200 /dev/nvme0n1
Could not create parition 2 from 2097152 to 18874368
Unable to set partition 2's name to 'disk-main-swap'!
Could not change partition 2's type code to 8200!
Error encountered; not saving changes.
+ sgdisk --change-name=2:disk-main-swap --typecode=2:8200 /dev/nvme0n1
+rm -rf /tmp/tmp.3s8Gz0C4ry
Question: what’s causing these errors? What can I do about it?
Here’s my disko config file:
# This must reflect the setup necessary for impermanence (with BTRFS
# See
# https://github.com/nix-community/disko/blob/3979285062d6781525cded0f6c4ff92e71376b55/docs/quickstart.md
# for installation instructions
# Lots of this is cribbed from
# https://github.com/chewblacka/nixos/blob/488ffc8c42b8553067687a19e96aeab33528a7fb/disko-config.nix
# (and then slightly simplified!)
  disko.devices = {
    disk = {
      main = {
        type = "disk";
        device = "/dev/nvme0n1";
        content = {
          type = "gpt";
          partitions = {
            ESP = {
              priority = 1;
              start = "1MiB";
              end = "1G";
              type = "EF00";
              content = {
                type = "filesystem";
                format = "vfat";
                mountpoint = "/boot";
            swap = {
              priority = 2;
              start = "1G";
              end = "9G";
              content = {
                type = "swap";
                randomEncryption = true; # ???
            # Most of the Real Stuff goes in here
            root = {
              priority = 3;
              start = "9G";
	      # Doing this because the new partition program (sgdisk, which replaced parted) doesn't support
	      # percentages. Hmfsk.
              end = "230G"; # "100%";
              content = {
                type = "btrfs";
                subvolumes = {
                  "/root" = {
                    mountpoint = "/";
                    mountOptions = [ "compress=zstd" "noatime" ];
                  "/home" = {
                    mountpoint = "/home";
                    mountOptions = [ "compress=zstd" ];
                  "/nix" = {
                    mountpoint = "/nix";
                  "/persistent" = {
                    mountpoint = "/persistent";
