I work with a Web development agency, and we run a Docker Compose setup for developing typical Django and FastAPI applications. This setup consists of a frontend, backend, database, an authentication and proxy container. Unfortunately, the network part of Docker appears to block traffic – only on NixOS.
The Docker Compose Setup
A simplified version of the setup would look like this:
# docker-compose.yml
services:
auth:
image: ghcr.io/zitadel/zitadel:stable
backend:
build:
context: ./backend
db:
image: postgres:17
frontend:
build:
context: ./frontend
proxy:
image: traefik:v2.10
command:
- --configFile=/traefik/config/static.yaml
ports:
- "443:8443"
The proxy setup is inspired by the Traefik proxy setup for local development from the Docker documentation. The traefik configuration routes requests at *.localhost:443
(or *.localhost:80
) from your local Webbrowser to the services running with Docker Compose.
# Traefik providers configuration
http:
routers:
auth:
rule: |
Host(`{{env "AUTH_DOMAIN"}}`) ||
HostRegexp(`{subdomain:[a-z]+}.{{env "AUTH_DOMAIN"}}`)
service: auth
backend:
rule: Host(`{{env "BACKEND_DOMAIN"}}`)
service: backend
frontend:
rule: Host(`{{env "FRONTEND_DOMAIN"}}`)
service: frontend
services:
auth:
loadBalancer:
servers:
# h2c is the scheme for unencrypted HTTP/2
- url: "h2c://auth:8080"
passHostHeader: true
backend:
loadBalancer:
servers:
- url: "http://backend:8000/"
frontend:
loadBalancer:
servers:
- url: "http://frontend:3000/"
tls:
certificates:
- certFile: /traefik/tls/cert.pem
keyFile: /traefik/tls/key.pem
As a developer, you bring up the setup by running docker compose up
and can then simply navigate between https://www.localhost, https://backend.localhost and https://auth.localhost, as if they were deployed out there in the Internet, which is veeery handy!
Works on other systems but not on NixOS
This has been proven to be a rocket-solid setup on macOS, Ubuntu Linux developer laptops and even runs on Windows in WSL. It all works: DNS resolution, network traffic, SSL certificates. With NixOS, unfortunately, we’re only somewhat 98% there.
$ docker compose up
The backend
container, which runs a Python web application (either Django or FastAPI) and is designed to make an authentication request against the auth
container, fails to connect through the proxy. With FastAPI (utilizzando fastapi-zitadel-auth) you get a
httpx.ConnectTimeout
… with Django (utilizzando django-allauth) you get a
requests.exceptions.ConnectTimeout
Inside the backend
container the various tools interestingly behave in a very different manner (e.g. cURL ignores /etc/hosts
and only uses the resolver defined in /etc/resolv.conf
, while ping
and nc
(netcat) honor the former), but the traffic seems to reach the proxy
service, which translates the request trying to forward it to the target service, which then times out.
Straightforward Docker setup
Docker is set up on my laptop running NixOS unstable the obvious way:
{ pkgs, ... }: {
environment.systemPackages = [ pkgs.gnome-boxes pkgs.vagrant ];
virtualisation = {
docker.enable = true;
docker.extraPackages = [ pkgs.docker-buildx ];
libvirtd.enable = true;
users.users.peter.extraGroups = [ "docker" "networkmanager" "wheel" ];
I originally tried to use rootless Docker, but that proved to cause additional networking issues, and I should use Docker instead of Podman to ensure everyone on the team uses the same setup. (Note: I kept libvirt, vagrant and boxes in the code snippet above just in case someone recognizes any known side-effects.)
Any ideas why the network traffic might be blocked?
