I have a customized xkb, which map capslock to right Ctrl and map right alt to Esc. I set services.xserver.xkbDir = ./xkb;, but it only works for kde/xfce/lxqt, doesn’t work for gnome/gdm. Only gnome-tweaks can change keymaps in gnome. What something wrong I did?
# your system. Help is available in the configuration.nix(5) man page
{ config, pkgs, ... }:
rec {
nix.settings.trusted-users = [ "root" "@wheel" ];
# basic {{{ #
imports =
# Include the results of the hardware scan.
./hardware-configuration.nix
boot.tmp.useTmpfs = true;
# https://discourse.nixos.org/t/i915-driver-has-bug-for-iris-xe-graphics/25006
boot.kernelParams = [ "i915.enable_psr=0" ];
nix.settings.substituters = [ "https://mirrors.bfsu.edu.cn/nix-channels/store" ];
hardware.enableAllFirmware = true;
security.sudo.wheelNeedsPassword = false;
networking.hostName = "laptop";
# Pick only one of the below networking options.
# networking.wireless.enable = true; # Enables wireless support via wpa_supplicant.
networking.networkmanager.enable = true; # Easiest to use and most distros use this by default.
# Open ports in the firewall.
networking.firewall.enable = false;
time.timeZone = "Asia/Shanghai";
console = {
font = "latarcyrheb-sun32";
useXkbConfig = true; # use xkbOptions in tty.
users.defaultUserShell = pkgs.zsh;
users.users.wzy = {
isNormalUser = true;
extraGroups = [ "wheel" "networkmanager" "input" "docker" ];
# Enable the OpenSSH daemon.
# Copy the NixOS configuration file and link it from the resulting system
# (/run/current-system/configuration.nix). This is useful in case you
# accidentally delete configuration.nix.
system.copySystemConfiguration = true;
system.stateVersion = "22.11"; # Did you read the comment?
# }}} basic #
# GUI {{{ #
i18n.inputMethod = {
enabled = "fcitx5";
i18n.inputMethod.fcitx5.addons = [ pkgs.fcitx5-rime ];
fonts.enableDefaultFonts = true;
fonts.fontDir.enable = true;
fonts.fonts = with pkgs; [
wqy_zenhei
wqy_microhei
(nerdfonts.override { fonts = [ "JetBrainsMono" ]; })
services.xserver.libinput.enable = true;
# Configure keymap in X11
services.xserver.displayManager.defaultSession = "gnome";
services.xserver.desktopManager.gnome.enable = services.xserver.displayManager.defaultSession == "gnome";
services.xserver.displayManager.gdm.enable = services.xserver.displayManager.defaultSession == "gnome";
services.xserver.desktopManager.plasma5.enable = services.xserver.displayManager.defaultSession == "plasma";
services.xserver.displayManager.sddm.enable = services.xserver.displayManager.defaultSession == "plasma";
services.xserver.desktopManager.lxqt.enable = services.xserver.displayManager.defaultSession == "lxqt";
services.xserver.desktopManager.xfce.enable = services.xserver.displayManager.defaultSession == "xfce";
services.xserver.displayManager.lightdm.greeters.slick.font.name = "Ubuntu 24";
# https://github.com/Freed-Wu/my-x11-keymaps
services.touchegg.enable = true;
services.picom = {
fade = true;
inactiveOpacity = 0.95;
settings = {
blur = {
kern = "3x3box";
background-exclude = [
"class_g ?= 'zoom'"
"window_type = 'dock'"
"class_g ?= 'wemeetapp'"
"name = 'rect-overlay'"
"window_type = 'desktop'"
"_GTK_FRAME_EXTENTS@:c"
shadow = true;
shadowExclude = [
"name = 'cpt_frame_xcb_window'"
"class_g ?= 'zoom'"
"name = 'Notification'"
"class_g = 'Conky'"
"class_g ?= 'Notify-osd'"
"class_g = 'Cairo-clock'"
services.xserver.excludePackages = [
pkgs.xterm
# Enable sound.
sound.enable = true;
hardware.pulseaudio.enable = true;
environment.lxqt.excludePackages = [
pkgs.lxqt.qterminal
environment.plasma5.excludePackages = [
pkgs.plasma5Packages.konsole
# }}} GUI #
nixpkgs.config.packageOverrides = pkgs: {
nur = import
builtins.fetchTarball
"https://github.com/nix-community/NUR/archive/master.tar.gz"
inherit pkgs;
# $ nix search wget
environment.systemPackages = with pkgs;
mulimgviewer = (
builtins.getFlake "github:nachifur/MulimgViewer"
).packages.${builtins.currentSystem}.default;
help2man = (
builtins.getFlake "github:Freed-Wu/help2man"
translate-shell = (
builtins.getFlake "github:Freed-Wu/translate-shell"
man-pages
man-pages-posix
glibcInfo
# python {{{ #
python3.withPackages (
p: with p; [
build
gdown
isort
pudb
ptpython
rich
colorama
beautifulsoup4
lxml
pandas
pytest
pip
dbus-python
jedi-language-server
tensorboard
torchWithoutCuda
torchvision
torchmetrics
sphinx
py-cpuinfo
mulimgviewer
help2man
# translate-shell
trash-cli
visidata
asciinema
pdd
grc
hyfetch
pre-commit
cmake-language-server
# }}} python #
# perl {{{ #
perl.withPackages (
p: with p; [
PerlTidy
po4a
rename
exiftool
parallel
# }}} perl #
# ruby {{{ #
ruby.withPackages (
p: with p; [
solargraph
rubocop
# }}} ruby #
# nodejs {{{ #
nodejs
nodePackages.gitmoji-cli
# }}} nodejs #
# rust {{{ #
manix
rnix-lsp
cargo
firefox
wezterm
onefetch
mdcat
exa
fd
vivid
delta
bat
ripgrep
bottom
hexyl
hyperfine
nixpkgs-fmt
texlab
typst
typst-lsp
# }}} rust #
# go {{{ #
go
fzf
scc
direnv
gh
wakatime
gdu
shfmt
git-lfs
cog
# }}} go #
# shell {{{ #
wgetpaste
pass
hr
lesspipe
bash-completion
zsh-completions
zsh-powerlevel10k
# }}} shell #
# haskell {{{ #
shellcheck
pandoc
cachix
# }}} haskell #
# f# {{{ #
marksman
# }}} f# #
# java {{{ #
pdftk
# }}} java #
# c {{{ #
sqlite
hello
lsb-release
gtk3
glib
xdotool
autoconf
automake
readline
gnumake
gcc
gdb
cgdb
neomutt
wget
curl
git
tmux
file
dos2unix
dmidecode
android-tools
scrcpy
pciutils
usbutils
texlive.combined.scheme-full
linux-firmware
p7zip
w3m
elinks
jq
acpi
zathura
ffmpeg
x264
moreutils
bc
num-utils
xsel
espeak-classic
# }}} c #
# c++ {{{ #
nur.repos.linyinfeng.wemeet
clang-tools
cmake
ninja
cling
x265
aria2
lftp
libsForQt5.yuview
luaformatter
lua-language-server
chafa
patchelf
ansifilter
libreoffice-fresh
# }}} c++ #
] ++ (if services.xserver.desktopManager.gnome.enable then [
gnome.gnome-tweaks
] else [ ]);
# program {{{ #
virtualisation.docker.enable = true;
virtualisation.docker.storageDriver = "btrfs";
virtualisation.docker.autoPrune.enable = true;
virtualisation.docker.rootless.enable = true;
virtualisation.docker.rootless.setSocketVariable = true;
services.dockerRegistry.enable = true;
services.dockerRegistry.enableDelete = true;
services.dockerRegistry.enableGarbageCollect = true;
services.v2raya.enable = true;
programs.proxychains.enable = true;
programs.proxychains.proxies = {
myproxy = {
type = "socks5";
host = "127.0.0.1";
port = 1080;
programs.less.envVariables = {
LESS = "--mouse -S -I -R -M";
programs.tmux.terminal = "screen-256color";
# started in user sessions.
programs.zsh.enable = true;
programs.zsh.enableBashCompletion = true;
programs.zsh.enableGlobalCompInit = true;
programs.zsh.autosuggestions.async = true;
programs.zsh.setOptions = [ "HIST_IGNORE_DUPS" "SHARE_HISTORY" "HIST_FCNTL_LOCK" "emacs" ];
programs.zsh.histSize = 20000;
programs.gnupg.agent = {
enableSSHSupport = true;
programs.neovim.enable = true;
programs.neovim.defaultEditor = true;
programs.neovim.vimAlias = true;
programs.neovim.viAlias = true;
programs.neovim.withNodeJs = true;
programs.neovim.configure = {
customRC = ''
if filereadable(stdpath('config') . '/init.vim')
execute 'source' stdpath('config') . '/init.vim'
endif
# }}} program #
# ex: foldmethod=marker
