Dolphin Theming Help QT
After updating to nix 25.05 my theming mechanisms; I simply followed the example in this post. And now after updating its not working the way it used to.
environment.systemPackages = with pkgs;
    libsForQt5.qtstyleplugin-kvantum
    libsForQt5.qt5ct
nixpkgs.config.qt5 = {
  platformTheme = "qt5ct";
    style = {
      package = pkgs.utterly-nord-plasma;
      name = "Utterly Nord Plasma";
I’m struggling on getting this working. I tried it for qt6, same issue. Nothing is taking. I don’t want to use stylix or home-manager (yet), I want something simple and works (as simple as the thing that used to work above). I just want everything in a dark theme, I don’t really care what at this point. Any ideas?
Also tried this:
  # night theme environment vars
  nixpkgs.config.qt6 = {
    platformTheme = "qt6ct";
      style = {
  environment.variables.QT_QPA_PLATFORMTHEME = "qt6ct";
Relevant packages enabled in my package list:
	lxappearance
	kdePackages.gwenview
  adwaita-qt
  adwaita-qt6
	materia-theme
	libsForQt5.ffmpegthumbs
	libsForQt5.kio-extras
	libsForQt5.kdegraphics-thumbnailers
  qt6Packages.qtstyleplugin-kvantum
	kdePackages.polkit-kde-agent-1
	kdePackages.dolphin
	kdePackages.qt6ct
	kdePackages.kde-cli-tools
	kdePackages.breeze-icons
	kdePackages.ark
	kdePackages.ark
	kdePackages.xdg-desktop-portal-kde
	kdePackages.kleopatra
  kdePackages.full
This is on an i3 setup fwiw
Referenced Post:
I’m pretty sure qt6ct doesn’t just automatically set the theme. Idk if home-manager manually configures by writing the theme name into its config. If not, run qt6ct in your terminal, then select the theme and close.
Also don’t set QT_QPA_PLATFORMTHEME manually, the home manager module does that for you.
Hello!
This setup configures Qt theming minimal declaratively, at the system level.
It works for Qt5 and Qt6, does not require Home Manager, and does not rely on GUI tools.
{ pkgs, ... }:
  environment = {
    systemPackages = with pkgs; [
      libsForQt5.qt5ct
      kdePackages.qt6ct
      adwaita-qt
    sessionVariables = {
      QT_QPA_PLATFORMTHEME = "qt5ct";
    etc = {
      "xdg/qt5ct/qt5ct.conf".text = ''
        [Appearance]
        style=adwaita-dark
      "xdg/qt6ct/qt6ct.conf".text = ''
        [Appearance]
        style=adwaita-dark
