I have a server with provides home directories through nfs, at path /home/lan. It is defined in my client’s configuration.nix as
services.cachefilesd.enable = true;
fileSystems."/home/lan" = {
device = "192.168.1.1:/home/lan";
fsType = "nfs";
options = ["fsc" "x-systemd.automount" "noauto" "x-systemd.idle-timeout=600"];
But on the client, this directory is mounted twice at the same path, as shown by the output of mount | grep /home/lan
systemd-1 on /home/lan type autofs (rw,relatime,fd=139,pgrp=1,timeout=600,minproto=5,maxproto=5,direct,pipe_ino=11118)
192.168.1.1:/home/lan on /home/lan type nfs4 (rw,relatime,vers=4.2,rsize=1048576,wsize=1048576,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.1.151,fsc,local_lock=none,addr=192.168.1.1)
I have another nfs mount at another path, but it doesn’t exhibit this behaviour. The only differences are, as far as I know
- that the home directories in home/lan are referred to in the OpenLDAP logging mechanism.
- that I have tried a configuration using autofs but I was long ago and I have reinstalled the system on the client from scratch, so that the only remaining traces can only be on the server.
Finally, I think that this is the cause of a problem I have, namely that I have an incessant succession of rpc.mountd attaching and detaching.
Has anyone got an idea on how to fix this?
