Dovecot installation problems ‘compiler-rt-6.0.1’ I on Darwin
Nixpkgs Search says aarch64-darwin in 23.05 is supported. however, when I install via environment.systemPackages I get the following error. I tried to override allow broken to see if I could get any further.
NIXPKGS_ALLOW_BROKEN=1; ./result/sw/bin/darwin-rebuild switch --flake .#xxx-MBP --verbose --show-trace;
error:
       … while evaluating the attribute 'activationScript' of the derivation 'darwin-system-23.05.20230711.8163a64+darwin4.eb22022'
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/pkgs/stdenv/generic/make-derivation.nix:303:7:
          302|     // (lib.optionalAttrs (attrs ? name || (attrs ? pname && attrs ? version)) {
          303|       name =
          304|         let
       … while evaluating call site
       at «none»:0: (source not available)
       … while calling 'g'
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/lib/attrsets.nix:595:19:
          594|           g =
          595|             name: value:
          596|             if isAttrs value && cond value
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/lib/attrsets.nix:598:20:
          597|               then recurse (path ++ [name]) value
          598|               else f (path ++ [name]) value;
          599|         in mapAttrs g;
       … while calling anonymous lambda
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/lib/modules.nix:248:72:
          247|           # For definitions that have an associated option
          248|           declaredConfig = mapAttrsRecursiveCond (v: ! isOption v) (_: v: v.value) options;
          249|
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/lib/modules.nix:759:9:
          758|     in warnDeprecation opt //
          759|       { value = builtins.addErrorContext "while evaluating the option `${showOption loc}':" value;
          760|         inherit (res.defsFinal') highestPrio;
       … while evaluating the option `system.activationScripts.script.text':
       … while evaluating the attribute 'mergedValue'
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/lib/modules.nix:794:5:
          793|     # Type-check the remaining definitions, and merge them. Or throw if no definitions.
          794|     mergedValue =
          795|       if isDefined then
       … while evaluating the attribute 'values'
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/lib/modules.nix:788:9:
          787|       in {
          788|         values = defs''';
          789|         inherit (defs'') highestPrio;
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/lib/modules.nix:887:7:
          886|     in {
          887|       values = concatMap (def: if getPrio def == highestPrio then [(strip def)] else []) defs;
          888|       inherit highestPrio;
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/lib/modules.nix:774:17:
          773|         # Process mkMerge and mkIf properties.
          774|         defs' = concatMap (m:
          775|           map (value: { inherit (m) file; inherit value; }) (builtins.addErrorContext "while evaluating definitions from `${m.file}':" (dischargeProperties m.value))
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/lib/modules.nix:774:28:
       … while evaluating definitions from `/nix/store/83pl8h2g55dbvnsgnrlkswfs52v10w7n-source/modules/system/activation-scripts.nix':
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/lib/modules.nix:775:137:
          776|         ) defs;
       … while calling 'dischargeProperties'
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/lib/modules.nix:846:25:
          845|   */
          846|   dischargeProperties = def:
          847|     if def._type or "" == "merge" then
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/lib/modules.nix:599:44:
          598|       defnsByName' = byName "config" (module: value:
          599|           [{ inherit (module) file; inherit value; }]
          600|         ) configs;
       … while calling 'g'
          594|           g =
          595|             name: value:
          599|         in mapAttrs g;
          249|
       … while evaluating the option `system.activationScripts.applications.text':
          794|     mergedValue =
          787|       in {
          886|     in {
       … while evaluating definitions from `/nix/store/83pl8h2g55dbvnsgnrlkswfs52v10w7n-source/modules/system/applications.nix':
          776|         ) defs;
          845|   */
          600|         ) configs;
       … while evaluating the attribute 'passAsFile' of the derivation 'system-applications'
          303|       name =
          304|         let
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/pkgs/build-support/buildenv/default.nix:77:5:
           76|     # XXX: The size is somewhat arbitrary
           77|     passAsFile = if builtins.stringLength pkgs >= 128*1024 then [ "pkgs" ] else [ ];
           78|   }
       … while evaluating the attribute 'buildInputs' of the derivation 'dovecot-2.3.20'
          303|       name =
          304|         let
       … while evaluating the attribute 'stdenv' of the derivation 'clucene-core-2.3.3.4'
          303|       name =
          304|         let
       … while evaluating the attribute 'defaultNativeBuildInputs' of the derivation 'stdenv-darwin'
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/pkgs/stdenv/generic/default.nix:93:14:
           92|     // {
           93|       inherit name;
           94|       inherit disallowedRequisites;
       … while evaluating the attribute 'depsTargetTargetPropagated' of the derivation 'clang-wrapper-6.0.1'
          303|       name =
          304|         let
       … while evaluating the attribute 'handled'
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/pkgs/stdenv/generic/check-meta.nix:447:7:
          446|       # or, alternatively, just output a warning message.
          447|       handled =
          448|         {
       … while evaluating the attribute 'no'
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/pkgs/stdenv/generic/check-meta.nix:449:11:
          448|         {
          449|           no = handleEvalIssue { inherit meta attrs; } { inherit (validity) reason errormsg; };
          450|           warn = handleEvalWarning { inherit meta attrs; } { inherit (validity) reason errormsg; };
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/pkgs/stdenv/generic/check-meta.nix:449:16:
          448|         {
       … while calling 'handleEvalIssue'
       at /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/pkgs/stdenv/generic/check-meta.nix:226:38:
          225|
          226|   handleEvalIssue = { meta, attrs }: { reason , errormsg ? "" }:
          227|     let
       error: Package ‘compiler-rt-6.0.1’ in /nix/store/7si351xc6vf7n4aa0kcnmb35an961wg7-source/pkgs/development/compilers/llvm/6/compiler-rt/default.nix:98 is marked as broken, refusing to evaluate.
       a) To temporarily allow broken packages, you can use an environment variable
          for a single invocation of the nix tools.
            $ export NIXPKGS_ALLOW_BROKEN=1
        Note: For `nix shell`, `nix build`, `nix develop` or any other Nix 2.4+
        (Flake) command, `--impure` must be passed in order to read this
        environment variable.
       b) For `nixos-rebuild` you can set
         { nixpkgs.config.allowBroken = true; }
       in configuration.nix to override this.
       c) For `nix-env`, `nix-build`, `nix-shell` or any other Nix command you can add
         { allowBroken = true; }
       to ~/.config/nixpkgs/config.nix.
Something is explicitly requesting a clang 6 stdenv, but clang 6 does not support aarch64-darwin. Whatever is requiring clang 6 will need to be fixed to build with a newer clang (ideally the one provided by the default stdenv).
