I’m using dwm on NixOS and building it through nixos-rebuild with a local source (~/.clones/dwm). Patches apply correctly, so the build is being compiled, but changes in config.def.h (like changing MODKEY to Super/Mod4) are not taking effect in the running session.
which dwm shows /run/current-system/sw/bin/dwm, so I’m definitely running the NixOS-managed binary via ly. The problem seems to be that Nix is either caching the previous build or not properly invalidating/rebuilding when config.def.h changes, so the compiled output doesn’t reflect my latest config changes even though patches in dwm.c do apply.
That’s not a thing with nix.
How exactly are you rebuilding? How did you add it to your config? What steps are you taking to restart dwm?
I think you need to restart the display-manager.service
Before restarting, the display manager won’t use the new environment variables.
If you use ‘whereis dwm’, the result will point to /nix/store. I don’t know why this is, but obviously, display managers prefer to use the latter.
So the usual short command (dwm) won’t be updated.
Creating a desktop file that uses the long command (/run/current-system/sw/bin/dwm) works.
I use this in my configuration:
{ pkgs, ... }:
mkDesktopEntry =
pkgs.writeTextFile {
inherit name text;
destination = "/share/wayland-sessions/${name}.desktop";
derivationArgs = {
passthru.providedSessions = [ name ];
services.displayManager.sessionPackages = [
(mkDesktopEntry "niri" ''
[Desktop Entry]
Name=Niri
Comment=Niri
Exec=/run/current-system/sw/bin/niri-wrapped
Type=Application
(niri-wrapped is a binary wrapper)
