Background:
I have blender-hip installed since I have an rx 7600 gpu on my server:
- CPU: AMD Ryzen 7 5700X (16) @ 4.66 GHz
- GPU: AMD Radeon RX 7600 [Discrete]
My system config is this: https://codeberg.org/BlastboomStrice/dotfiles/src/.config/nixos-config/hosts/nixos-base/configuration.nix
- I have enabled these:
hardware.graphics = {
enable32Bit = true;
hardware.amdgpu.opencl.enable = true;
My system metadata is here
- system:
"x86_64-linux" - host os:
Linux 6.12.63, NixOS, 26.05 (Yarara), 26.05.20251228.c0b0e0f - multi-user?:
yes - sandbox:
yes - version:
nix-env (Lix, like Nix) 2.94.0 System type: x86_64-linux Additional system types: i686-linux, x86_64-v1-linux, x86_64-v2-linux, x86_64-v3-linux Features: gc, signed-caches System configuration file: /etc/nix/nix.conf User configuration files: /home/base/.config/nix/nix.conf:/home/base/.config/kdedefaults/nix/nix.conf:/etc/xdg/nix/nix.conf:/home/base/.nix-profile/etc/xdg/nix/nix.conf:/nix/profile/etc/xdg/nix/nix.conf:/home/base/.local/state/nix/profile/etc/xdg/nix/nix.conf:/etc/profiles/per-user/base/etc/xdg/nix/nix.conf:/nix/var/nix/profiles/default/etc/xdg/nix/nix.conf:/run/current-system/sw/etc/xdg/nix/nix.conf Store directory: /nix/store State directory: /nix/var/nix Data directory: /nix/store/azv639a070gjjjr2h0bld6kf30xxr65y-lix-2.94.0/share - nixpkgs:
/nix/store/xzl5dhddgjxp2p18h5qpkhvlkp8128j1-source
In blender in:
Edit/Preferences/System:- I have chosen
HIP - Enabled both RX7600 gpu and Ryzen 7 5700X
- Did not enable
HIP RTbecause it makes system crash when using Cycles with Gpu - Kept display graphics at
OpenGL
- I have chosen
- In Render options:
- I have chosen
CyclesasRendering Engine - I have chosen
GPU ComputeasDevice- I have also tried using
CPU
- I have
Denoiseenabled only in Render- I also tried turning it off
- I have chosen
Issue
Using htop to monitor both cpu and gpu usage, blender seems to use the gpu ONLY to display, not render.
- Looking around an object in cycles the cpu usage stays at around 10% while gpu goes to around 20%. But as soon as I stop looking around and let the frame render, gpu usage drops to around 0% and the cpu stays at around 10% (that’s cause I see practically one thread goes to 100%).
- When rendering the frame (by pressing
F12) the cpu usage goes to around 100%, while gpu goes to 1% (probably to display the image). - During all these, htop reports 0.0%
computeusage for the gpu, onlygfxusage seems to change
Expected behaviour
Blender should use the gpu when rendering.
