I’m able to compile elm-format
(or at least it’s building the world right now) like this:
nix-build '<nixpkgs>' -A pkgsCross.aarch64-multiplatform.pkgsStatic.elmPackages.elm-format
But when I try the same with elm
this happens:
error: attribute 'runtimeShell' missing
at /nix/store/0c10w4am1xhxjkrmnd8d6rbksvm68311-source/pkgs/top-level/all-packages.nix:867:17:
866| substitutions = {
867| shell = targetPackages.runtimeShell;
868| passthru.tests = tests.makeWrapper;
I think I can provide some runtimeShell value with --arg runtimeShell someValue
, but I’m:
- not sure what that value would be
- not sure if I’m on the right path or this is just a bug
Hoping someone can clarify what to do here.
Thanks!
Here is the --show-trace
version if it helps:
$ nix-build '<nixpkgs>' -A pkgsCross.aarch64-multiplatform.pkgsStatic.elmPackages.elm --show-trace
… while evaluating the attribute 'shell' of the derivation 'hook'
at /nix/store/0c10w4am1xhxjkrmnd8d6rbksvm68311-source/pkgs/stdenv/generic/make-derivation.nix:270:7:
269| // (lib.optionalAttrs (attrs ? name || (attrs ? pname && attrs ? version)) {
270| name =
271| let
… while evaluating the attribute 'nativeBuildInputs' of the derivation 'elm-static-aarch64-unknown-linux-musl-0.19.1'
270| name =
271| let
I found some related issues on nixpkgs seemingly related to makeWrapper not being in buildInputs and… I think… this means something doesn’t happen on the cross host.
Here is the issue I created: https://github.com/NixOS/nixpkgs/issues/188296
