Errors in Icon-Shelf Project Packaging
Package Name: icon-shelf
Version: 0.1.18
Project Homepage: <https://icon-shelf.github.io/>
Source Code: <https://github.com/Icon-Shelf/icon-shelf>
Iconshelf.nix: <https://gist.github.com>
Build Issues:
When running nixos-rebuild switch, the following errors occur:
npm ERR! code EAI_AGAIN
npm ERR! syscall getaddrinfo
npm ERR! errno EAI_AGAIN
npm ERR! request to https://registry.npmjs.org/yocto-queue/-/yocto-queue-0.1.0.tgz failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
npm ERR! Log files were not written due to an error writing to the directory: /homeless-shelter/.npm/_logs
npm ERR! You can rerun the command with `--loglevel=verbose` to see the logs in your terminal
It seems that there are issues with downloading the dependency yocto-queue from the npm registry. The error suggests that it may be related to DNS resolution or network connectivity problems.
Steps to Reproduce:
  1. Create iconshelf.nix like the one above.
  2. Run nixos-rebuild switch to build and switch to the new configuration.
Expected Behavior:
After running nixos-rebuild switch, the package should be built successfully, and the icon-shelf application should be available for use.
Actual Behavior:
The build process fails, and the package is not created due to the above-mentioned errors.
My knowledge of packaging is limited so any suggestions on how to resolve these issues would be greatly appreciated. Thank you for your time and assistance!
