Errors while building system
Hi everyone I’m trying to switch my config to using flakes but I’m running into these errors when I run the command sudo nixos-rebuild switch --flake .
error: 1 dependencies of derivation '/nix/store/mxaqi6wnq38a0773sqvianx2wjc9jlgb-os-prober-1.83.drv' failed to build
error: 1 dependencies of derivation '/nix/store/ys28iw1knrxzk8g5klvix1q0z21hz7gv-grub-config.xml.drv' failed to build
error: 1 dependencies of derivation '/nix/store/xzfk4lzhb0v6qvwnc3s6zanrr13ps0qn-install-grub.sh.drv' failed to build
error: 1 dependencies of derivation '/nix/store/f9giykkyn67f3vsixdnvi61g33k910hr-nixos-system-nixos-25.05.20241227.634fd46.drv' failed to build
Here are my config files:
Configuration.nix
{ config, pkgs, ... }:
  imports =
      ./hardware-configuration.nix
      ./nvidia.nix
  # Bootloader.
  #boot.loader.systemd-boot.enable = true;
  #boot.loader.efi.canTouchEfiVariables = true;
  boot.loader.grub.enable = true;
  boot.loader.grub.devices = [ "nodev" ];
  boot.loader.grub.useOSProber = true;  # Use OS Prober to detect Windows
  boot.loader.grub.efiSupport = true;
  # Zen kernel
  #boot.kernelPackages = pkgs.linuxPackages_zen;
  # Ntfs support
  boot.supportedFilesystems = [ "ntfs" ];
  # Enable networking
  # Enable the GNOME Desktop Environment.
  #services.xserver.displayManager.gdm.enable = true;
  #services.xserver.desktopManager.gnome.enable = true;
  # Configure keymap in X11
  services.xserver.xkb = {
    layout = "us";
    variant = "";
  # Enable sound with pipewire.
  security.rtkit.enable = true;
  services.pipewire = {
    alsa.enable = true;
    alsa.support32Bit = true;
    pulse.enable = true;
    #jack.enable = true;
    #media-session.enable = true;
  users.users.ruvik = {
    isNormalUser = true;
    description = "Ruvik Victoriano";
    packages = with pkgs; [
    #  thunderbird
  # Install firefox.
  #programs.firefox.enable = true;
  # Allow unfree packages
  # $ nix search wget
  	vim # Do not forget to add an editor to edit configuration.nix! The Nano editor is also installed by default.
  	ffmpeg-full
	toybox
  	ntfs3g
	kitty
	yazi
	firefox
	btop
	fish
	eza
	file
	which
	tree
	mpv
	zstd
	yt-dlp
	networkmanagerapplet
	pulseaudio
	fzf
	gedit
	git
	yt-dlp
	mpv
	evince
	nautilus
	nwg-look
	hyprshade
	adwaita-icon-theme
	#Screenshotting
	hyprshot
	wl-clipboard
	# Nvidia
	vaapiVdpau
	libvdpau
  	libvdpau-va-gl
 	nvidia-vaapi-driver
 	vdpauinfo
	libva
        libva-utils
	# GStreamer
        gst_all_1.gstreamer # Video/Audio data composition framework tools like "gst-inspect", "gst-launch" ...
        gst_all_1.gst-plugins-base # Common plugins like "filesrc" to combine within e.g. gst-launch
        gst_all_1.gst-plugins-good
        gst_all_1.gst-plugins-bad
        gst_all_1.gst-plugins-ugly
        gst_all_1.gst-libav # Plugins to reuse ffmpeg to play almost every video format
        gst_all_1.gst-vaapi # Support the Video Audio (Hardware) Acceleration API
        # Web Privacy
	mullvad-browser
	protonvpn-gui
  	# C and C++ development environment
	gcc
   	clang
    	gdb    # Debugger
    	cmake
	# Editor
	vscode-fhs
	lxqt.lxqt-policykit
  # Enable the Flakes feature and the accompanying new nix command-line tool
  services = {
  displayManager = {
      defaultSession = "hyprland-uwsm";
      sddm = {
        theme = "catppuccin-mocha";
        package = pkgs.kdePackages.sddm;
        wayland.enable = true;
  services.gnome.gnome-keyring.enable = true;
  security.pam.services.sddm.enableGnomeKeyring = true;
  # Flatpak support
  fonts = {
    enableDefaultPackages = true;
      font-awesome
      noto-fonts
      corefonts
      nerd-fonts.hack
      nerd-fonts.jetbrains-mono
  programs = {
    zsh.enable = true;
    hyprland = {
      withUWSM = true;
      xwayland.enable = true;
  xdg.portal = {
    extraPortals = [
      pkgs.xdg-desktop-portal-gtk
  # zram
  zramSwap = {
	priority = 100;
	memoryPercent = 100;
	swapDevices = 1;
    algorithm = "zstd";
  # Cpu powersave
  boot.kernelParams = [ "amd_pstate=guided" ];
  powerManagement.enable = true;
  powerManagement.cpuFreqGovernor = "schedutil";
  # started in user sessions.
  # programs.mtr.enable = true;
  # programs.gnupg.agent = {
  #   enable = true;
  #   enableSSHSupport = true;
  # Enable the OpenSSH daemon.
  # Open ports in the firewall.
  system.stateVersion = "24.11"; # Did you read the comment?
flake.nix
    home-manager = {
  outputs = inputs@{ nixpkgs, home-manager, ...}: {
    nixosConfigurations = {
      nixos = nixpkgs.lib.nixosSystem {
	system = "x86_64-linux";
        modules = [
          ./configuration.nix
            home-manager.users.ruvik = import ./home-manager;
I’ve tried to run nix-collect-garbage and delete the paths manually from /nix/store/ but nothing changes. What can I do? Thx
Did you have systemd-boot setup before? Without seeing more of the error log, you might want to try sudo nixos-rebuild --install-bootloader boot --flake <path>. Otherwise, if you are trying this on a VM, you might need to add boot.loader.grub.efiInstallAsRemovable = true (but I believe the error would manifest in a different way if that was the issue).
You might want to run efibootmgr to see if there is anything unsuspected going on.
I’m getting a very similar error:
error: builder for '/nix/store/6gq1rkbzsdbdrdqp2i3w0ylx0x98znah-dmraid-1.0.0.rc16.drv' failed with exit code 2;
       last 25 log lines:
       > make -C tools
       > make[1]: Entering directory '/build/dmraid/1.0.0.rc16/tools'
       > gcc -MM -MF dmraid.d -I  -I. -I../include -I../lib -O2 -DDMRAID_NATIVE_LOG -DHAVE_GETOPTLONG -fPIC -Wall -Wundef -Wcast-align -Wwrite-strings -Winline -DDMRAID_TEST -DDMRAID_AUTOREGISTER -O2 -D_LARGEFILE64_SOURCE dmraid.c; \
       > gcc -c -I  -I. -I../include -I../lib -O2 -DDMRAID_NATIVE_LOG -DHAVE_GETOPTLONG -fPIC -Wall -Wundef -Wcast-align -Wwrite-strings -Winline -DDMRAID_TEST -DDMRAID_AUTOREGISTER -O2 -D_LARGEFILE64_SOURCE dmraid.c -o dmraid.o
       > gcc -MM -MF commands.d -I  -I. -I../include -I../lib -O2 -DDMRAID_NATIVE_LOG -DHAVE_GETOPTLONG -fPIC -Wall -Wundef -Wcast-align -Wwrite-strings -Winline -DDMRAID_TEST -DDMRAID_AUTOREGISTER -O2 -D_LARGEFILE64_SOURCE commands.c; \
       > gcc -c -I  -I. -I../include -I../lib -O2 -DDMRAID_NATIVE_LOG -DHAVE_GETOPTLONG -fPIC -Wall -Wundef -Wcast-align -Wwrite-strings -Winline -DDMRAID_TEST -DDMRAID_AUTOREGISTER -O2 -D_LARGEFILE64_SOURCE commands.c -o commands.o
       > gcc -MM -MF toollib.d -I  -I. -I../include -I../lib -O2 -DDMRAID_NATIVE_LOG -DHAVE_GETOPTLONG -fPIC -Wall -Wundef -Wcast-align -Wwrite-strings -Winline -DDMRAID_TEST -DDMRAID_AUTOREGISTER -O2 -D_LARGEFILE64_SOURCE toollib.c; \
       > gcc -c -I  -I. -I../include -I../lib -O2 -DDMRAID_NATIVE_LOG -DHAVE_GETOPTLONG -fPIC -Wall -Wundef -Wcast-align -Wwrite-strings -Winline -DDMRAID_TEST -DDMRAID_AUTOREGISTER -O2 -D_LARGEFILE64_SOURCE toollib.c -o toollib.o
       > gcc -o dmraid dmraid.o commands.o toollib.o -rdynamic -L../lib \
       >       -L/nix/store/75k5rywwbb24z7g463cixdh4qnxisjc0-dmraid-1.0.0.rc16/lib -ldmraid -ldevmapper -ldevmapper-event -ldmraid -ldevmapper -ldl
       > gcc -o dmevent_tool dmevent_tool.c -I  -I. -I../include -I../lib -rdynamic -L../lib \
       > dmevent_tool.c:126:8: error: return type defaults to 'int' [8;;https://gcc.gnu.org/onlinedocs/gcc-14.2.0/gcc/Warning-Options.html#index-Wimplicit-int-Wimplicit-int8;;]
       >   126 | static _process_opt(int opt, const char *cmd)
       > dmevent_tool.c: In function '_process_opt':
       > dmevent_tool.c:151:25: error: 'return' with no value, in function returning non-void [8;;https://gcc.gnu.org/onlinedocs/gcc-14.2.0/gcc/Warning-Options.html#index-Wno-return-mismatch-Wreturn-mismatch8;;]
       >   151 |                         return;
       > dmevent_tool.c:126:8: note: declared here
       > make[1]: *** [Makefile:78: dmevent_tool] Error 1
       > make[1]: Leaving directory '/build/dmraid/1.0.0.rc16/tools'
       > make: *** [make.tmpl:115: tools] Error 2
       For full logs, run 'nix log /nix/store/6gq1rkbzsdbdrdqp2i3w0ylx0x98znah-dmraid-1.0.0.rc16.drv'.
error: 1 dependencies of derivation '/nix/store/9m8g0l9kf10d5553vzryxkvwlwjjddxg-grub-config.xml.drv' failed to build
error: 1 dependencies of derivation '/nix/store/ywmcbmi5n6c4505ql6lw1lrcngs5aw2h-install-grub.sh.drv' failed to build
error: 1 dependencies of derivation '/nix/store/ygnmd7sl5i9365bg293achjvxzhsc9pw-nixos-system-nixos-25.05.20241227.634fd46.drv' failed to build
looks like dmraid has a build error, the make output was included for me.
Build failure: dmraid · Issue #367926 · NixOS/nixpkgs · GitHub seems to be relevant, it was fixed and merged into master two days ago, unstable should get the fix soon.
You’re right, my bad I didn’t copy that part also. That seems to be the problem
you could wait for the fix to make it into the unstable branch (you can check the status, which shows the last release, here: https://status.nixos.org/) or you could switch your flake.nix to the stable version.
