Firmware failed to load
Due to the specific hardware, I need to add some extra firmware packages:
hardware.firmware = lib.mkBefore [ pkgs.linux-firmware-xxx ];
I used nix repl to inspect the corresponding derivation and its output, and confirmed that the files do exist.
However, after rebuilding the system and rebooting, I still get β€˜file not found’ errors in dmesg:
remoteproc remoteproc1: Direct firmware load for qcom/sm8150/xiaomi/nabu/cdsp.mbn failed with error -2
remoteproc remoteproc2: Direct firmware load for qcom/sm8150/xiaomi/nabu/adsp.mbn failed with error -2
remoteproc remoteproc1: request_firmware failed: -2
remoteproc remoteproc2: request_firmware failed: -2
On other distros, the expected output looks like this:
remoteproc remoteproc1: Booting fw image qcom/sm8150/xiaomi/nabu/cdsp.mbn, size 9455252
remoteproc remoteproc1: remote processor cdsp is now up
remoteproc remoteproc2: Booting fw image qcom/sm8150/xiaomi/nabu/adsp.mbn, size 14430684
remoteproc remoteproc2: remote processor adsp is now up
Any ideas on how to fix this? Am I doing something wrong?
Hrm… I lost you at -xxx. What is that? Did you make that package? Can you confirm the file layout of its out path?
Yes, it’s a package I built myself. Here’s how I verified it:
# First, get the output path
nix path-info --impure .#nixosConfigurations.XiaomiNabu.config.hardware.firmware.outPath
# Then inspect it with tree
tree -l /nix/store/xxxxxxxx
part of the output:
/nix/store/15mb693r73cyid19vz35s7w6sn7v6ir0-firmware
└── lib
    └── firmware
        β”œβ”€β”€ qcom
        β”‚   β”œβ”€β”€ sm8150
        β”‚   β”‚   └── xiaomi -> /nix/store/rim02j2isk0ch9065fj15qcxgkbkh9ms-linux-firmware-xiaomi-nabu-25.04.26-zstd/lib/firmware/qcom/sm8150/xiaomi
        β”‚   β”‚       └── nabu
        β”‚   β”‚           β”œβ”€β”€ a640_zap.mbn.zst
        β”‚   β”‚           β”œβ”€β”€ adsp.mbn.zst
        β”‚   β”‚           β”œβ”€β”€ cdsp.mbn.zst
        β”‚   β”‚           β”œβ”€β”€ modem.mbn.zst
        β”‚   β”‚           β”œβ”€β”€ modemuw.jsn.zst
        β”‚   β”‚           β”œβ”€β”€ slpi_nb.mbn.zst
        β”‚   β”‚           β”œβ”€β”€ venus.mbn.zst
        β”‚   β”‚           └── wlanmdsp.mbn.zst
That firmware doesn’t seem to be referenced by mainline Linux, is there an out of tree module that’s trying to load the firmware?
You could also try disabling firmware compression (NixOS Search) as it’s incompatible with partial firmware reads.
What’s interesting is that other files packaged alongside themare being recognized:
[   12.360025] remoteproc remoteproc0: powering up modem
[   12.417207] remoteproc remoteproc0: Booting fw image qcom/sm8150/xiaomi/nabu/modem.mbn, size 5101612
So modem.mbn loads fine from the same package, but cdsp.mbn and adsp.mbn don’t. They’re all in the same directory, same derivation output. This is really puzzling.
Solved! I used boot.initrd.extraFirmwarePaths to force-load the firmware early in the boot process. This ensures the files are available before remoteproc tries to look for them, so the β€˜file not found’ issue is gone.
