Fix ssl.SSLCertVerificationError with uv's Standalone Python
TLDR Solution: uv’s standalone Python looks for CA certificates at /etc/ssl/cert.pem, but NixOS uses /etc/ssl/certs/ca-bundle.crt. Add this to your configuration.nix:
# Fix uv python ssl.SSLCertVerificationError
environment.etc.certfile = {
  source = "/etc/ssl/certs/ca-bundle.crt";
  target = "ssl/cert.pem";
Problem Description
I’m encountering ssl.SSLCertVerificationError when using urllib.request with uv’s standalone Python installation on NixOS. Any HTTPS request fails with certificate verification errors.
Error Details
  File "/home/u/.local/share/uv/python/cpython-3.13.6-linux-x86_64-gnu/lib/python3.13/urllib/request.py", line 1319, in do_open
    h.request(req.get_method(), req.selector, req.data, headers,
              encode_chunked=req.has_header('Transfer-encoding'))
  # ... stack trace abbreviated ...
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1035)
Test Case
from urllib import request
with request.urlopen("https://github.com/langchain-ai/react-agent/archive/refs/heads/main.zip") as response:
    assert response.status == 200
    data = response.read()
    print("resp len", len(data))
Root Cause Analysis
Using strace, I discovered that uv’s Python is looking for certificate files in the wrong locations:
strace -ff uv run python test.py
The relevant output shows:
[pid 164907] openat(AT_FDCWD, "/etc/ssl/cert.pem", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 164907] stat("/etc/ssl/certs/c2d044ad.0", 0x7ffda0bdae78) = -1 ENOENT (No such file or directory)
# ... multiple failed attempts to find certificate files ...
The issue: uv’s standalone Python expects system CA certificates at /etc/ssl/cert.pem, but NixOS stores them at /etc/ssl/certs/ca-bundle.crt.
Temporary Workaround
As a temporary fix, you can set the SSL_CERT_FILE environment variable:
export SSL_CERT_FILE=/etc/ssl/certs/ca-bundle.crt
Permanent Solution
For a permanent fix on NixOS, add this to your configuration.nix:
This creates a symbolic link from the expected location to the actual certificate bundle location.
I’d rather think that we should configure or patch the package in nixpkgs to look on usual path (or consider hardcoding to ${cacert}/..., etc.)
