For a flake I’m writing I want to package my project for both local use on any default system as well as have target for linux/amd64 Docker runtimes. As such, I started out writing a flake making use of flake-utils
and its eachDefaultSystem
util.
However, my Docker output should not be built for each system, rather, it should only be built for aarch64-linux.
How would I accomplish this? To my mind I should somehow merge the outputs generated from the eachDefaultSystem
util with some manual (?) buildLayeredImage
output targeting aarch64-linux only.
My question to you all; is this the right way to approach this and how would I go about achieving such?
While I think the question is pretty general, I have included a slightly redacted version of my current flake below. As you can see, the docker image is currently built for each default system, this breaks on macOS because tini
is not availble there, but is undesirable in general for my use.
Thanks!
description = "My project";
cargo2nix.url = "github:cargo2nix/cargo2nix/release-0.11.0";
devshell.url = "github:numtide/devshell";
flake-utils.follows = "cargo2nix/flake-utils";
nixpkgs.follows = "cargo2nix/nixpkgs";
outputs = inputs: with inputs;
pkgs = import nixpkgs {
inherit system;
overlays = [
devshell.overlays.default
cargo2nix.overlays.default
rustPkgs = pkgs.rustBuilder.makePackageSet {
rustVersion = "1.75.0";
# generated up front with cargo2nix
packageFun = import ./my-project/Cargo.nix;
packageOverrides = pkgs: pkgs.rustBuilder.overrides.all ++ [
# parentheses disambiguate each makeOverride call as a single list element
(pkgs.rustBuilder.rustLib.makeOverride {
name = "cmake";
overrideAttrs = drv: {
propagatedBuildInputs = drv.propagatedBuildInputs or [ ] ++ [
pkgs.cmake
pkgs.openssl
in rec {
name = "My Project name";
packages = {
client = (rustPkgs.workspace.my-project {});
docker = pkgs.dockerTools.buildLayeredImage {
name = "registry.company.local/tenant/my-project";
tag = "0.0.1-snapshot";
created = builtins.substring 0 8 self.lastModifiedDate;
config.Entrypoint = "${pkgs.tini}/bin/tini --";
config.Cmd = "${packages.client}/bin/my-project";
contents = with pkgs; [ tini ];
default = packages.client;
devShells = rec {
rustShell = pkgs.devshell.mkShell {
commands = [];
env = [
name = "AMQP_ADDR";
value = "amqp://<user>:<password>@some.broker.io:5672/my-vhost";
name = "RUST_LOG";
value = "info";
packages = with pkgs; [
rabbitmq-server
cargo
packages.client
default = rustShell;
