Hello, hope it follows appropriate place.
I’m new to Nix and trying to do following:
- We’re using nix (flake.nix) for Artiq system. It’s a quantum computer control system.
You can find more information about Artiq with Nix from here:
https://m-labs.hk/artiq/manual/installing.html
- Based on pre-built flake.nix file, what I want to do is add libraries (Spinnaker SDK and PySpin).
Spinnaker SDK is C++ camera library and PySpin is python binding for this.
You can find more information about this from here:
(You might need to log-in to access the second link).
Since Spinnaker SDK and PySpin isn’t on nixpackage, I’ve created the derivation and trying to install on the Nix.
The file directories are following:
aqpcontrol (top directory)
|-flake.nix
|-spinnaker-deb.nix
|-spinnaker_python.nix
|-spinnaker-debs
| |-(contains .deb files)
|-spinnaker-whl
| |-spinnaker_python.whl
The way to install this in the “local” computer (not through flake.nix) is run install.sh file which basically install every .deb files and install .whl file. Then we can import PySpin in the .py.
I didn’t include every .deb files on git, but added a .whl file.
Two derivation and flake.nix I’ve created is following:
flake.nix
inputs.extrapkg.url = "git+https://git.m-labs.hk/M-Labs/artiq-extrapkg.git?ref=release-8";
inputs.spinnaker-debs = {
type = "path";
path = "./spinnaker-debs";
flake = false;
outputs = { self, extrapkg, spinnaker-debs}:
pkgs = extrapkg.pkgs;
artiq = extrapkg.packages.x86_64-linux;
# Originally it was spinnaker_python-4.2.0.46-cp310-cp310-linux_x86_64.whl. I changed the name.
spinnaker_whl = ./spinnaker-whl/spinnaker_python-4.2.0.46-cp310-cp310-linux_x86_64.whl;
# Spinnaker SDK derivation import
spinnaker = import ./spinnaker-sdk.nix {
inherit (pkgs) stdenv dpkg lib;
spinnaker_debs = spinnaker-debs;
# Spinnaker_python wheel derivation import
spinnaker_python = import ./spinnaker_python.nix {
inherit pkgs;
inherit (pkgs) lib stdenv;
buildPythonPackage = pkgs.python310Packages.buildPythonPackage;
inherit spinnaker spinnaker_whl;
myPython = pkgs.python310.withPackages(ps: [
spinnaker_python
#test integrattion of artiq with spinnaker
artiq.artiq
ps.pandasps.matplotlib
ps.pyvisa
ps.pyvisa-py
devShells.x86_64-linux = builtins.mapAttrs makePythonShell pythonVersions;
buildInputs = [
spinnaker
myPython
shellHook = ''
export SPINNAKER_ROOT=${spinnaker}
export LD_LIBRARY_PATH=${spinnaker}/lib:$LD_LIBRARY_PATH
export CPLUS_INCLUDE_PATH=${spinnaker}/include
echo "Spinnaker dev environment activated!"
packages.x86_64-linux.spinnaker_python = spinnaker_python;
# This section defines the new environment
packages.x86_64-linux.default = pkgs.buildEnv {
name = "artiq-env";
paths = [
# ADD PACKAGES BELOW
(pkgs.python3.withPackages(ps : [
# List desired Python packages here.
#artiq.artiq
myPython
#ps.paramiko # needed if and only if flashing boards remotely (artiq_flash -H)
#artiq.flake8-artiq
#artiq.dax
#artiq.dax-applets
# The NixOS package collection contains many other packages that you may find
# interesting. Here are some examples:
#ps.pandas
#ps.numba
#ps.matplotlib
#ps.pyvisa
#ps.pyvisa-py
# or if you need Qt (will recompile):
#(ps.matplotlib.override { enableQt = true; })
#ps.bokeh
#ps.cirq
#ps.qiskit
# Note that NixOS also provides packages ps.numpy and ps.scipy, but it is
# not necessary to explicitly add these, since they are dependencies of
# ARTIQ and incorporated with an ARTIQ install anyway.
# List desired non-Python packages here
# Additional NDSPs can be included:
#artiq.korad_ka3005p
#artiq.novatech409b
# Other potentially interesting non-Python packages from the NixOS package collection:
#pkgs.gtkwave
#pkgs.spyder
#pkgs.R
#pkgs.julia
# ADD PACKAGES ABOVE
# This section configures additional settings to be able to use M-Labs binary caches
nixConfig = { # work around https://github.com/NixOS/nix/issues/6771
extra-trusted-public-keys = "nixbld.m-labs.hk-1:5aSRVA5b320xbNvu30tqxVPXpld73bhtOeH6uAjRyHc=";
extra-substituters = "https://nixbld.m-labs.hk";
{ pkgs, lib, stdenv, buildPythonPackage, spinnaker, spinnaker_whl }:
fixedWheel = pkgs.runCommand "fixed-wheel" {
nativeBuildInputs = [ pkgs.coreutils ];
mkdir -p $out
cp ${spinnaker_whl} $out/spinnaker_python-4.2.0.46-cp310-cp310-linux_x86_64.whl
buildPythonPackage rec {
pname = "spinnaker_python";
version = "4.2.0.46";
format = "wheel";
src = "${fixedWheel}/spinnaker_python-4.2.0.46-cp310-cp310-linux_x86_64.whl";
propagatedBuildInputs = [ spinnaker ];
postInstall = ''
echo "Patching _PySpin shared object..."
sofile=$(find $out -name '_PySpin*.so' | head -n1 || true)
if [ -n "$sofile" ]; then
patchelf --set-rpath ${spinnaker}/lib:$(patchelf --print-rpath "$sofile") "$sofile"
else
echo "Warning: _PySpin*.so not found!"
fi
pythonImportsCheck = [ "PySpin" ];
shellHook = ''
preCheck = ''
meta = with lib; {
description = "FLIR Spinnaker Python bindings";
platforms = platforms.linux;
Finally,
spinnaker-sdk.nix
{ stdenv, dpkg, lib, spinnaker_debs }:
stdenv.mkDerivation rec {
pname = "spinnaker-sdk";
src = spinnaker_debs;
nativeBuildInputs = [ dpkg ];
unpackPhase = ''
for deb in $src/*.deb; do
echo "Unpacking $deb..."
dpkg-deb -x "$deb" .
done
installPhase = ''
mkdir -p $out
cp -r * $out/
meta = with lib; {
description = "Spinnaker SDK from FLIR (.deb unpacked)";
The problem is, when I tried to import PySpin after develop it, it doesn’t recognize PySpin library. Also, from the
nix build .#spinnaker_python --show-trace
I realized that .whil flie doesn’t recognize .so files.
error: builder for '/nix/store/pg2sbl4wx9pf3l38fq581fzc8izhhg4w-python3.10-spinnaker_python-4.2.0.46.drv' failed with exit code 1;
last 25 log lines:
> checking for references to /build/ in /nix/store/0fwhkzjsqvzvzrzcp1cxag2b6d0n0jql-python3.10-spinnaker_python-4.2.0.46-dist...
> patching script interpreter paths in /nix/store/0fwhkzjsqvzvzrzcp1cxag2b6d0n0jql-python3.10-spinnaker_python-4.2.0.46-dist
> Executing pythonRemoveTestsDir
> Finished executing pythonRemoveTestsDir
> Running phase: installCheckPhase
> no Makefile or custom installCheckPhase, doing nothing
> Running phase: pythonCatchConflictsPhase
> Running phase: pythonRemoveBinBytecodePhase
> Running phase: pythonImportsCheckPhase
> Executing pythonImportsCheckPhase
> Check whether the following modules can be imported: PySpin
> Traceback (most recent call last):
> File "<string>", line 1, in <module>
> File "<string>", line 1, in <lambda>
> File "/nix/store/wm85wvkj8w9lk3s53k6s3zkgi5p4xf2j-python3-3.10.17/lib/python3.10/importlib/__init__.py", line 126, in import_module
> return _bootstrap._gcd_import(name[level:], package, level)
> File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
> File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
> File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
> File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
> File "<frozen importlib._bootstrap_external>", line 883, in exec_module
> File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
> File "/nix/store/m87nsd4r5a0ipmskqmhl44k2kzgs023b-python3.10-spinnaker_python-4.2.0.46/lib/python3.10/site-packages/PySpin.py", line 15, in <module>
> import _PySpin
> ImportError: libSpinnaker.so.4: cannot open shared object file: No such file or directory
For full logs, run:
While I’m writing down this question, I realized that even I added
pythonVersions = {
python38 = pkgs.python38;
python39 = pkgs.python39;
python310 = pkgs.python310;
default = pkgs.python310;
# A function to make a shell with a python version
makePythonShell = shellName: pythonPackage: pkgs.mkShell {
# You could add extra packages you need here too
packages = [ pythonPackage ];
# You can also add commands that run on shell startup with shellHook
shellHook = ''
echo "Now entering ${shellName} environment."
and set environment as python 3.10, it seems like nix environment still use python 3.12 only. Does this the main reason? since Spinnaker SDK only supports 3.10.
Also does anyone tried to add C++ libraries with python bindings on Nix? If so, could you give me advise to fix this error?
Sorry for the unorganized questions and any advises would be very appreciated.
Thanks
-Ohik
