I’ve been trying to build mach-nix
the flakes way and among the problems I ran into I noticed that nix show github:DavHau/mach-nix
fails with
a ‘aarch64-linux’ with features {} is required to build '/nix/store/2646…
I had an impression that nix show
must work by only looking at flake.nix
and flake.lock
, without any evaluations, and in particular should not require cross-compiling the project. My hypothesis is that current flake.nix
somehow breaks the expected interface and does more than declare outputs, but I cannot quite figure out what is the required change (I tried some messing around: Flake.nix by SomeoneSerge · Pull Request #1 · SomeoneSerge/mach-nix · GitHub)
TLDR: Am I right that nix show
should just work, and how do I make it work?
Thanks
