I can’t get overlays to work in flake-parts and I’m not sure what I am doing wrong. As far as I can tell, I am doing exactly what the flake-parts documentation recommends. I am trying to rewrite my config using flake-parts and I keep getting errors that a package from an overlay is missing.
Edit: I originally had @azuwis’s solution marked as the solution because it worked fine and seemed to be the best fit for my case. However, it caused issues after I started using the ez-config module. I changed it to @StepBroBD’s solution because it seems to work fine even with ez-config.
I used sudo nixos-rebuild test to rebuild my config and the error is below.
For context, scratchpad is the name of a package in the hyprland-contrib flake.
Also, just in case it’s relevant, if I use a way other than an overlay to get the package, it’ll just show a similar error for the other overlay I have defined.
error:
at /nix/store/0jr2kk95c34c0b6yxi75q4fqgb43kqkm-source/lib/attrsets.nix:1575:11:
1574| || pred here (elemAt values 1) (head values) then
1575| head values
1576| else
at /nix/store/0jr2kk95c34c0b6yxi75q4fqgb43kqkm-source/lib/modules.nix:821:9:
820| in warnDeprecation opt //
821| { value = addErrorContext "while evaluating the option `${showOption loc}':" value;
822| inherit (res.defsFinal') highestPrio;
error: attribute 'scratchpad' missing
at /nix/store/asz1z1w3kk3silwp2jar0nikgwrn0hwv-source/home/hyprland.nix:125:37:
124|
125| "$scratchpad" = "${lib.getExe pkgs.scratchpad} -m '$menu --dmenu'";
126|
Anything you can do at the top level, you can do in perSystem as well, although you may have to @ match those module arguments.
For example, add change the top level function header to e.g. toplevel@{ config, ... }: /*...*/ so you can access toplevel.config despite plain config being shadowed by perSystem = { config, ... }: /*...*/.
I’m a bit unsure what your question is. Do you mean: why don’t we set pkgs in nixosSystem with the pkgs in toplevel.config.<some attr path>?
I traced toplevel.config, and there’re lots of stuff in there. IMO withSystem and getSystem is a easier way to get the pkgs out from toplevel than direct access with attribute path, they all do the same thing
perSystem ’s _module.args.pkgs will NOT affect your NixOS system configurations. It only affects the use of pkgs in perSystem blocks.
In order to accessible from another point, a local var in nix need be in lexical scope ( like it’s in case of with e1: e2 , e2 can access it as with makes it available to its lexical scope ), atrrs can be copied ( in a let in {} block}, similarly with rec {} ,
In your own solution ( autopilot ), you put perSystem = {} (is perSystem = :_ isthat some sort of overlay, whereas_module.args` was about accessing modules? idk* ) in outer -files ( iirc) .
In any case , I wasn’t commenting on what should be done, but merely meant that inputs/ (arg for modules) can be passed in multiple ways so long as they can be accessed. May be I should ve consulted the whole context of the thread, before putting a comment .
At this point I d like to emphasise the question *
