Hey everyone,
happy to introduce flake-programs-sqlite, a simple flake to automagically specify programs.sqlite for command-not-found.
Why?
NixOS systems configured with flakes often don’t have a channel set (e.g. nix-channel --list shows no channel), which usually results in a broken command-not-found as the command database is part of the channel system and not part of nixpkgs.
Up to now the only option was to use nix-index, but it was not possible to get back the UX known from channels. (see here)
With flake-programs-sqlite a working command-not-found only requires a few additions to a flake based system configuration.
How?
flake-programs-sqlite makes use of a mapping from git commit hashes to channel names. This mapping is updated by a GitHub action by scraping {channels,releases}.nixos.org (currently) about every ten minutes.
When importing flake-programs-sqlite, the standard flake mechanism can be used to pin it’s nixpkgs input. When the programs-sqlite output package is requested, a fixed output derivation for a programs.sqlite database matching the revision of the input nixpkgs is constructed from the scraped data. The result of this derivation is then injected into command-not-found.
NixOS Module Integration
Using flake-programs-sqlite as a module in your NixOS configuration is the preferred method. Just add it to your flake inputs, pass it to your outputs and add it to your list of modules:
inputs.fps.url = "github:wamserma/flake-programs-sqlite";
inputs.fps.inputs.nixpkgs.follows = "nixpkgs";
outputs = { nixpkgs, fps, ... }: {
nixosConfigurations.mymachine = nixpkgs.lib.nixosSystem {
modules =
(import configuration.nix)
fps.nixosModules.programs-sqlite
Contribute
Feel free to submit issues or pull requests on the GitHub repository.
Note
Scraping started on 21st December 2022. If a certain channel revision is missing, follow the README for instructions on scraping or open an issue.
