Flakes and nix.channel.enable
hi everyone! :grinning_cat:
i use flakes, that means i dont need nix.channel.enable, right..? channels =/= flakes, yeah..?
well, there is a .nix-profile file and a .nix-defexpr folder that randomly (re)appear (after deletion) in my $HOME with (empty) channels and (full) channels_root subfolders in it that are also seem to be dead symlinks. there are also these warnings i get on every update (with the option above set to false):
warning: /root/.nix-defexpr/channels exists, but channels have been disabled.
warning: /nix/var/nix/profiles/per-user/root/channels exists, but channels have been disabled.
Due to https://github.com/NixOS/nix/issues/9574, Nix may still use these channels when NIX_PATH is unset.
Delete the above directory or directories to prevent this.
my $NIX_PATH is nixpkgs=flake:nixpkgs, which was automatically set (?). is it okay to delete those (aforementioned) directories..? or should i just not touch that option..? these warnings dont happen without the option. also, was i supposed to disable that option immediately (after switching to flakes), cos i forgot, so its a problem now..?
okay, this known issue was closed. but it is still not clear to me - is this a normal, expected behaviour in the form of a warning, then..? meaning it wasnt solved, actually..? which then means that i do have to delete those lingering directories, right..?
thanks!!!
P.S. sorry if i missed something obvious… im not good at understanding htings… :crying_cat:
It’s telling you your system isn’t completely free of channels, despite you setting the option, unless you delete those directories. If you haven’t set NIX_PATH in a way so that <nixpkgs> goes somewhere other than channels, deleting them might still cause a problem, but it sounds like you have, so deleting them should be fine.
i deleted $HOME/.nix-profile, $HOME/.nix-defexpr/ and the contents of /nix/var/nix/profiles/per-user/root/ (or should i also delete ../per-user/, there is nothing besides an empty root/ folder there?). also, my (other) /root/ folder (in /) is empty (?) when i tried cd / and sudo ls root/ there, so i didnt touch it. the dead symlinks that i mentioned are still there, though, in the /nix/store/…
anyway, the warnings are gone now and these folders are no longer being created (again), so thank you!!! :grinning_cat:
edit: SORRY i know this is gonna bump it, but i just wanna share something similarly interesting (this is for the future readers if my vaguely titled OP comes up first in search results…):
