Flatpak applications not using my set cursor
Good day/evening everyone,
This should (hopefully) be a simple one, despite the finicky nature of flatpaks. So, as the title states, I can not get flatpak applications to use the cursor theme that I set. Let me firstly share with you how I set said cursor theme:
buuf-cursor-heart = pkgs.stdenvNoCC.mkDerivation {
    pname = "buuf-cursor-heart";
    version = "master";
    src = pkgs.fetchurl {
      url = "https://cdn.discordapp.com/attachments/156048223314640896/1217582363610189976/buuf-cursor-heart-24-a.tar.gz?ex=66048cf1&is=65f217f1&hm=c0a36941976578400cd12a7fefd4236785a94d17e19c784ee6f01d0afcb45984&";
      hash = "sha256-ZKqWw0Itro9CQIJyouLxel76C80kie8EYkmm2Kc0iJs=";
    dontPatch = true;
    dontConfigure = true;
    dontBuild = true;
    dontFixup = true;
    installPhase = ''
      mkdir -p $out/share/icons/buuf-cursor-heart
      mv * $out/share/icons/buuf-cursor-heart/
  home.packages = (with pkgs; [
    buuf-cursor-heart
  qt = {
    platformTheme = "qtct";
    style.name = "kvantum";
  gtk = {
    theme = {
      name = "Dracula";
      package = pkgs.dracula-theme;
    gtk3.extraConfig = {
      gtk-application-prefer-dark-theme = 1;
    gtk4.extraConfig = {
    iconTheme = {
      name = "Buuf For Many Desktops";
      package = buuf-nestort;
    cursorTheme = {
      package = buuf-cursor-heart;
      size = 24;
   home.pointerCursor = {
     size = 24;
     gtk.enable = true;
     x11.enable = true;
After a lot of looking around, I found this wiki page: Fonts - NixOS Wiki. I tried out the bindfs, flatpak overriding and symlinking proposed solutions. None have made any difference at the end though. Was I supposed to, perhaps, change anything in the bindfs code block, instead of just copy pasting it into my config file?
Anything else I can do in general?
Solution: So, what I did was, I simply allowed access, to one of the flatpak applications, to the entire file system, using flatseal. The cursor was then finally fixed. It was really silly. But I had to try out a bunch of nix store paths, after listing them with a find command. At the end I was able to find the path that did the trick.
Needless to say, this solution is surely not reproducible and will break sooner or later when the path changes…
Had the same problem. But after half a year i finally found a solution.
Setting the cursor theme
Setting the cursor theme under home-manager with home.pointerCursor should be enough:
  size = 24;
Gnome Apps under Hyprland (at least for me) need an extra kick with:
wayland.windowManager.hyprland.settings = {
  exec-once = [
    # Fixes cursor themes in gnome apps under hyprland
    "gsettings set org.gnome.desktop.interface cursor-theme '${config.home.pointerCursor.name}'"
    "gsettings set org.gnome.desktop.interface cursor-size ${toString home.pointerCursor.size}"
Fixing cursor themes for flatpaks
But for flatpaks you also need to make sure the xdg-desktop-portal-gtk is running, which is not automatically always the case (espacially on tiling windowManagers). So in home-manager you can set:
xdg.portal = {
  extraPortals = [ pkgs.xdg-desktop-portal-gtk ]; # Fixes OpenURI and cursor theme in flatpaks
This already fixes themes for most apps like gnome. But not all (e.g. Obsidian or Logseq).
And since flatpaks are sandboxed and dont have access to the nix-store you need to give them permission, since the cursors are eventually linked to /nix/store/...:
flatpak --user override --filesystem=/nix/store:ro
# OR with the https://github.com/gmodena/nix-flatpak homeManagerModule
services.flatpak = {
  overrides = {
    global = {
      # [Metadata keywords](https://docs.flatpak.org/en/latest/flatpak-command-reference.html?highlight=override#flatpak-metadata)
      Context.filesystems = [
        "/nix/store:ro"
I hope this helps!
