networking.interfaces.wlp0s20f3.ipv4.routes = [{
address = "1.2.3.4";
via = "5.6.7.8";
, then I get
error: The option `networking.interfaces.wlp0s20f3.ipv4.routes."[definition 1-entry 1]".prefixLength' is used but not defined.
If I try to specify
prefixLength = "24";
, then I get:
error: A definition for option `networking.interfaces.wlp0s20f3.ipv4.routes."[definition 1-entry 1]".prefixLength' is not of type `signed integer'. Definition values:
- In `/etc/nixos/configuration.nix': "24"
Right;) Thanks, but I still get an error after it has run
okt. 31 09:44:10 ximian network-addresses-wlp0s20f3-start[2003582]: adding route 1.2.3.4/24... 'ip route add 1.2.3.4/24 via 5.6.7.8 dev wlp0s20f3' failed: Error: Invalid prefix for given prefix length.
okt. 31 09:44:10 ximian systemd[1]: network-addresses-wlp0s20f3.service: Main process exited, code=exited, status=1/FAILURE
okt. 31 09:44:10 ximian systemd[1]: network-addresses-wlp0s20f3.service: Failed with result 'exit-code'.
okt. 31 09:44:10 ximian systemd[1]: Failed to start Address configuration of wlp0s20f3.
I commented on the nixos options aspects, because I am not entirely sure what you are trying to do here considering that your IP addresses seem to be place holders? If you are literally using 1.2.3.4, that’s a full IPv4 address, so the prefixLength should probably be 32 then. If you’d like to use a prefixLength of 24, use an IP with that many bits set, e.g. 1.2.3.0. Or so, hard to be sure for me without context
