So, I decided to try to jump into nixos-unstable
this weekend (which maybe is a little silly given the impending arrival of 20.03, but I was persuaded that nixos-unstable
wasn’t any worse than, say, Arch…), and I’ve run into a problem that looks a bit like issue #84043, except at a more critical point…
Changing channels from nixos-19.09
to nixos-unstable
and the initial nixos-rebuild boot --upgrade
went fine. Rebooted, and everything seems more-or-less fine (only issue is that I’m seeing problems unlocking kwallet
that look like #68316). I made a few more additional tweaks and attempting to rebuild, I now get the following:
unpacking channels...
building Nix...
/nix/store/rm1hz1lybxangc8sdl7xvzs5dcvigvf7-bash-4.4-p23/bin/bash: relocation error: /nix/store/an6bdv4phxsz14q2sk57iscl2dc7bnj1-glibc-2.30/lib/libpthread.so.0: symbol __write_nocancel version GLIBC_PRIVATE not defined in file libc.so.6 with link time reference
File "/nix/store/ax8ymnyrh05r1rjvnbyv1cba4p1q3akv-systemd-boot-builder.py", line 240, in <module>
main()
File "/nix/store/ax8ymnyrh05r1rjvnbyv1cba4p1q3akv-systemd-boot-builder.py", line 209, in main
write_entry(*gen, machine_id)
File "/nix/store/ax8ymnyrh05r1rjvnbyv1cba4p1q3akv-systemd-boot-builder.py", line 95, in write_entry
subprocess.check_call([append_initrd_secrets, "/boot%s" % (initrd)])
File "/nix/store/vs4vj1yzqj1bkcqkf3b6sxm6jfy1gb4j-python3-3.7.7/lib/python3.7/subprocess.py", line 363, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/nix/store/i8cmnrjnnc21yix0005sb4y2n9qimxjk-append-initrd-secrets/bin/append-initrd-secrets', '/boot/efi/nixos/p0mkgxr2681w192m6j69ga0lzp3hzhbs-initrd-linux-5.4.24-initrd.efi']' returned non-zero exit status 127.
Reverting all of the tweaks to my configuration and attempting a rebuild results in the same error… So it looks like I’m stuck, unable to switch to a new configuration.
Anyone run into something like this, or have any idea how to work-around or resolve?
Hoping I don’t have to figure out how to get back on 19.09 before Monday, since this is my normal desktop… Any help or ideas super-appreciated!
