Hi, I’ve had issues updating Grafana on my VPS, on aarch64-linux.
This is the error:
error: builder for '/nix/store/iag2knr35vhw160jpfzh5nxwfcpzafj0-grafana-12.0.2.drv' failed with exit code 1;
last 9 log lines:
> Running phase: unpackPhase
> unpacking source archive /nix/store/qincqp9238rcgn5qji03a693ii5ig1fj-source
> source root is source
> Running phase: patchPhase
> Running phase: updateAutotoolsGnuConfigScriptsPhase
> Running phase: configurePhase
> wire: err: exit status 1: stderr: go: go.work requires go >= 1.24.4 (running go 1.24.3; GOTOOLCHAIN=local)
> wire: generate failed
For full logs, run:
nix log /nix/store/iag2knr35vhw160jpfzh5nxwfcpzafj0-grafana-12.0.2.drv
The error log isn’t really helpful sadly:
@nix { "action": "setPhase", "phase": "unpackPhase" }
@nix { "action": "setPhase", "phase": "patchPhase" }
@nix { "action": "setPhase", "phase": "updateAutotoolsGnuConfigScriptsPhase" }
@nix { "action": "setPhase", "phase": "configurePhase" }
I haven’t found anything on Github, and obviously the hydra build doesn’t fail, so honestly idk what I’m doing wrong specifically.
I’m on 25.05. and on Github the Go Version is patched to 1.24.4, so I don’t know why the build is using 1.24.3
This is the config:
{ config, pkgs, helpers, systemSettings, userSettings, ... }:
url = systemSettings.extraSettings.privateUrl;
port = 2345;
services.grafana = {
settings = {
server = {
http_addr = "127.0.0.1";
http_port = port; # default: 3000
enable_gzip = true;
security.admin_email = systemSettings.extraSettings.email;
analytics.reporting_enabled = false;
provision = {
dashboards.settings.providers = [
{ name = "Overview"; options.path = ./dashboards/node.json; }
datasources.settings = {
datasources.settings.deleteDatasources = let
delete = name: { orgId = 1; name = name; };
in [
(delete "VictoriaMetrics - Prometheus")
declarativePlugins = with pkgs.grafanaPlugins; [
victoriametrics-metrics-datasource
victoriametrics-logs-datasource
I don’t think theres any other Go instance installed, at least there’s nothing in the global path and I don’t add the package anywhere explicitly.
