Hey, I’m trying to move from KDE to hyprland, but it halves my battery life, which is only 4 hours to start with. nixos config`
I read on the wiki that I should use tlp, however, when I rebuild, I get a failed assertion - You have set services.power-profiles-daemon.enable = true; which conflicts with services.tlp.enable = true;
I have the system76 scheduler enabled, because my laptop is a System76 Gaze18, but commenting that didn’t help. I’m not sure what is setting services.power-profiles-daemon.enable = true.
I’m also not sure why this isn’t an issue on KDE.
