I’m trying to create a simple haskell shell with a single package (split
) based on haskellPackages.shellFor
Hence I wrote a shell as so:
outputs =
{ self, nixpkgs }:
devShells.x86_64-linux.default =
p = nixpkgs.legacyPackages.x86_64-linux;
p.haskellPackages.shellFor {
packages = h: [
h.split
nativeBuildInputs = [
p.haskell-language-server
split
’s package appears to have the correct structure (?)
$ nix build nixpkgs#haskellPackages.split --no-link --print-out-paths | xargs tree
/nix/store/mg6m6bkkqd98qvnly0kfbnjjr4r6r195-split-0.2.5
└── lib
└── ghc-9.6.6
└── lib
├── package.conf.d
│ └── split-0.2.5-ASm9S4CWxpg5KjSJ1ec3hG.conf
<snip...>
I also have a simple test file:
import Data.List.Split
main = undefined
However, trying to build this file results in the following error:
ghc -v test.hs
Glasgow Haskell Compiler, Version 9.6.6, stage 2 booted by GHC version 9.2.4
*** initializing unit database:
package flags []
loading package database /nix/store/2f7lv6caiwwysi4r44s4vy60glj4lbq1-ghc-9.6.6-with-packages/lib/ghc-9.6.6/lib/package.conf.d
wired-in package ghc-prim mapped to ghc-prim-0.10.0
wired-in package ghc-bignum mapped to ghc-bignum-1.3
wired-in package base mapped to base-4.18.2.1
wired-in package rts mapped to rts-1.0.2
wired-in package template-haskell mapped to template-haskell-2.20.0.0
wired-in package ghc mapped to ghc-9.6.6
!!! initializing unit database: finished in 11.62 milliseconds, allocated 3.771 megabytes
*** Chasing dependencies:
Chasing modules from: main:test.hs
!!! Chasing dependencies: finished in 0.35 milliseconds, allocated 0.344 megabytes
Ready for upsweep
[SingleModule(main:Main []), SingleModule(LN: [main:Main])]
compile: input file test.hs
*** Checking old interface for Main (use -ddump-hi-diffs for more details):
[1 of 2] Compiling Main ( test.hs, test.o )
*** Parser [Main]:
!!! Parser [Main]: finished in 0.08 milliseconds, allocated 0.075 megabytes
*** Renamer/typechecker [Main]:
!!! Renamer/typechecker [Main]: finished in 2.90 milliseconds, allocated 4.504 megabytes
test.hs:1:1: error:
Could not find module ‘Data.List.Split’
Locations searched:
Data/List/Split.hs
Data/List/Split.lhs
Data/List/Split.hsig
Data/List/Split.lhsig
1 | import Data.List.Split
I also checked the contents of the package database dir, and don’t see the split
package listed at all:
$ l /nix/store/2f7lv6caiwwysi4r44s4vy60glj4lbq1-ghc-9.6.6-with-packages/lib/ghc-9.6.6/lib/package.conf.d | rg split
lrwxrwxrwx 3 root root 138 Dec 31 1969 splitmix-0.1.0.5-1g4Y67JB8lK4ODDsw0vzN6.conf -> /nix/store/vh2bnim5r7gh3jgcfbm1m15f85gi90p5-splitmix-0.1.0.5/lib/ghc-9.6.6/lib/package.conf.d/splitmix-0.1.0.5-1g4Y67JB8lK4ODDsw0vzN6.conf
How would I go about fixing this shell expression to make the module visible to ghc
