Hi, i installed the following dependencies:
xorg.libXtst gtk3 xorg.libXext xorg.libXi jdk17 javaPackages.openjfx17
Verifying archive integrity… 100% All good.
Uncompressing XiaoMiTool V2 100%
Exception in thread “main” java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at java.base/sun.launcher.LauncherHelper$FXHelper.main(Unknown Source)
Caused by: java.lang.RuntimeException: java.lang.UnsatisfiedLinkError: /tmp/selfgz4043418274/lib/libglassgtk3.so: libXtst.so.6: cannot open shared object file: No such file or directory
at javafx.graphics/com.sun.javafx.tk.quantum.QuantumToolkit.startup(Unknown Source)
at javafx.graphics/com.sun.javafx.application.PlatformImpl.startup(Unknown Source)
at javafx.graphics/com.sun.javafx.application.LauncherImpl.startToolkit(Unknown Source)
at javafx.graphics/com.sun.javafx.application.LauncherImpl.launchApplicationWithArgs(Unknown Source)
at javafx.graphics/com.sun.javafx.application.LauncherImpl.launchApplication(Unknown Source)
… 5 more
Caused by: java.lang.UnsatisfiedLinkError: /tmp/selfgz4043418274/lib/libglassgtk3.so: libXtst.so.6: cannot open shared object file: No such file or directory
at java.base/java.lang.ClassLoader$NativeLibrary.load0(Native Method)
at java.base/java.lang.ClassLoader$NativeLibrary.load(Unknown Source)
at java.base/java.lang.ClassLoader$NativeLibrary.loadLibrary(Unknown Source)
at java.base/java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.base/java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.base/java.lang.Runtime.loadLibrary0(Unknown Source)
at java.base/java.lang.System.loadLibrary(Unknown Source)
at javafx.graphics/com.sun.glass.utils.NativeLibLoader.loadLibraryInternal(Unknown Source)
at javafx.graphics/com.sun.glass.utils.NativeLibLoader.loadLibrary(Unknown Source)
at javafx.graphics/com.sun.glass.ui.gtk.GtkApplication.lambda$new$6(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
at javafx.graphics/com.sun.glass.ui.gtk.GtkApplication.(Unknown Source)
at javafx.graphics/com.sun.glass.ui.gtk.GtkPlatformFactory.createApplication(Unknown Source)
at javafx.graphics/com.sun.glass.ui.Application.run(Unknown Source)
