Summary:
- Trying to build
ocaml-lsp
which isn’t part ofnixpkgs
ocaml-lsp
builds, but I don’t get a binary - If I run the
make lsp-server
command through a hook, the build fails and complains about missing dependencies - I’m unsure which deps go in
buildInputs
and which inpropagatedBuildInputs
and how the git submodules affect this whole process (for OCaml in general andocaml-lsp
in particular)
I want to play around with OCaml. I checked the setup instructions but decided to skip opam
and see how far I can get with just Nix. Most packages are easy to build with buildDunePackage
but I just can’t get ocaml-lsp
to build. Part of the reason is probably my complete lack of understanding of Dune and OCaml in general.
Here’s what I currently have in shell.nix
, with some (hopefully) irrelevant details ellided (the entire file can be found in this gist)
ocaml-lsp = pkgs.ocaml-ng.ocamlPackages_4_09.buildDunePackage rec {
pname = "lsp";
version = "latest";
ocaml = pkgs.ocaml-ng.ocamlPackages_4_09.ocaml;
minimumOCamlVersion = "4.06.1";
src = pkgs.fetchgit {
url = "https://github.com/ocaml/ocaml-lsp";
sha256 = "0jlh6zxrdcnfdbici2gwwk4j83hb2fvlnf285wpcbdwh08w14afa";
fetchSubmodules = true;
useDune2 = true;
buildInputs = [
propagatedBuildInputs = [
pkgs.ocaml-ng.ocamlPackages_4_09.yojson
ppx_yojson_conv_lib
pkgs.ocaml-ng.ocamlPackages_4_09.stdlib-shims
pkgs.ocaml-ng.ocamlPackages_4_09.menhir
pkgs.ocaml-ng.ocamlPackages_4_09.cmdliner
pkgs.ocaml-ng.ocamlPackages_4_09.merlin
cinaps
doCheck = false;
preInstall = ''
make lsp-server
As you can see I’m installing a bunch of dependencies, which where reported as missing during the make lsp-server
part (I tried various combinations of buildInputs
and propagatedBuildInputs
). The interesting thing is that it works if I omit the make lsp-server
part, but then I don’t get the actual ocamllsp
binary. The build instructions for ocaml-lsp
mention these steps:
# clone repo with submodules
git clone --recursive git@github.com:ocaml/ocaml-lsp.git
# if you already cloned, pull submodules
git submodule update --init --recursive
# create local switch (or use global one)
opam switch create . ocaml-base-compiler.4.09.1
# install dependencies
opam install . --deps-only --with-test
# build
make build
# install ocamllsp
make lsp-server
Notice that they’re installing at least some dependencies as git submodules.
I looked at other OCaml packages in the Nix repository but I couldn’t find anything similar. I’m a bit lost and I’m unsure if I should ask in a more OCaml-specific place or here. Right now the error I’m getting is
File "ocaml-lsp-server/src/dune", line 8, characters 16-37:
8 | merlin.utils merlin.query_commands result yojson ppx_yojson_conv_lib
Error: Library "merlin.query_commands" not found.
Hint: try: dune external-lib-deps --missing @install
Here’s a gist with the entire shell.nix
file.
Lastly, I can build and install the program successfully with opam
if I follow their instructions. But relying on a 3rd party build tool which Nix has no control over whatsoever would be a last resort. I’m in no rush with this whole OCaml thing and my primary goal here is to understand what I’m doing wrong and if it’s the Nix part or the OCaml part.
