I’m attempting to add podman-py using the Python build instructions for pypi packages. I’m getting an error that `module ‘podman’ has no attribute ‘version’.
Here’s the error and partial configuration.nix. It builds fine on my Fedora laptop with the classic setup.py build --user
Anyone have any ideas how to fix?
Solved. The requirements changed between versions and I was usingtomli
instead of toml
so the version wasn’t getting correctly parsed from the source. For reference:
my-python-packages = p: with p; [
buildPythonPackage rec {
pname = "podman";
version = "4.4.1";
src = fetchPypi {
inherit pname version;
sha256 = "sha256-pvvNBgPTBRnc0F5d2waVq5BBjNBuLeloXQ/D0taUad4=";
doCheck = false;
propagatedBuildInputs = [
# Specify dependencies
pkgs.python310Packages.pyxdg
pkgs.python310Packages.requests
pkgs.python310Packages.setuptools
pkgs.python310Packages.sphinx
pkgs.python310Packages.toml
pkgs.python310Packages.urllib3
pkgs.python310Packages.wheel
