After recently updating my nix installation as per the manual I’m now facing a strange collision between myPackages and jdk11 (specifically), though it’s likely a general change in behaviour I don’t understand.
% nix-channel --update; nix-env -iA nixpkgs.nix nixpkgs.cacert
% nix-shell -p nix-info --run "nix-info -m"
- system: `"x86_64-darwin"`
- host os: `Darwin 20.3.0, macOS 10.16`
- multi-user?: `no`
- sandbox: `no`
- version: `nix-env (Nix) 2.3.10`
- channels(ldeck): `"nixpkgs-21.05pre281594.6fc2b7ecc2a"`
- nixpkgs: `/Users/ldeck/.nix-defexpr/channels/nixpkgs`
% nix-env -iA nixpkgs.myPackages
replacing old 'my-packages'
installing 'my-packages'
/nix/store/azz5r490c3pi4ppfcl77x4wdz185p9hr-my-packages.drv
building '/nix/store/azz5r490c3pi4ppfcl77x4wdz185p9hr-my-packages.drv'...
Use of uninitialized value $stat2 in numeric ne (!=) at /nix/store/vg1f180bvkk5ijmcfwflp8cwnf59al1r-builder.pl line 94.
Use of uninitialized value $stat1 in numeric ne (!=) at /nix/store/vg1f180bvkk5ijmcfwflp8cwnf59al1r-builder.pl line 94.
collision between `/nix/store/m2b1pdx0wf00sv01xw1shy5nscmk8fyl-zulu15.28.51-ca-jdk-15.0.1/share/man' and `'
builder for '/nix/store/azz5r490c3pi4ppfcl77x4wdz185p9hr-my-packages.drv' failed with exit code 2
error: build of '/nix/store/azz5r490c3pi4ppfcl77x4wdz185p9hr-my-packages.drv' failed
My single user config looks like this (and specifically available here, though I’ve not pushed the latest changes yet as it’s broken):
allowUnfree = true;
packageOverrides = pkgs: with pkgs; rec {
java_default = jdk15_headless;
java_home = pkgs.writeShellScriptBin "java_home" ''
if [ "$#" -ne 2 ] || [ "$1" != "-v" ] || [ "$2" -lt 8 ]; then
echo "Usage: $0 -v <version>";
exit 1;
fi
case "$2" in
8)
JDK="${jdk8}"
JDK="${jdk11}"
esac
echo "$JDK"
myPackages = buildEnv {
name = "my-packages";
paths = [
(runCommand "profile" {} ''
mkdir -p $out/etc/profile.d
cp ${myProfile} $out/etc/profile.d/my-profile.sh
java_default
java_home
pathsToLink = [ "/share/man" "/share/doc" "/bin" "/etc" "/Applications" ];
extraOutputsToInstall = [ "man" "doc" ];
This used to update happily, so not sure what changed.
Is it a question of setting the priority, somehow, for one of the packages?
They seem to be attempting to install the same man page path.
