Help configuring zsh in home-manager
I want to set up zsh and oh-my-zsh
My home.nix is:
{ pkgs, ... }: {
  home.username = "shmuel";
  home.homeDirectory = "/home/shmuel";
  home.packages = with pkgs; [
    pkgs.oh-my-zsh
  programs.zsh = {
  ... # Your zsh config
  shellAliases = {
    ll = "ls -l";
    update = "sudo nixos-rebuild switch";
 oh-my-zsh = {
    plugins = [ ];
    theme = "agnoster";
When rebuilding, I get this error:
error:
         at /nix/store/bg5fbkfa5x53clcjf4p5p92k1l3w8x38-source/lib/attrsets.nix:960:11:
          959|         || pred here (elemAt values 1) (head values) then
          960|           head values
          961|         else
         at /nix/store/bg5fbkfa5x53clcjf4p5p92k1l3w8x38-source/lib/modules.nix:809:9:
          808|     in warnDeprecation opt //
          809|       { value = builtins.addErrorContext "while evaluating the option `${showOption loc}':" value;
          810|         inherit (res.defsFinal') highestPrio;
       error: syntax error, unexpected ID, expecting '}'
       at /nix/store/9ginqzv6dbjhkga5d23skczw3n143ah9-source/home.nix:11:3:
           10|   ... # Your zsh config
           11|   enable = true;
           12|   shellAliases = {
Is this line part of your file or did you remove some part?
Given that this line appears in the error message literally, they did not remove it.
@shmu26, please remove the line, the ... has a certain meaning in a certain context, and it always have to be the last thing in a set pattern, thats why you get an error here.
Thanks to the both of you. Now new error:
error:
          960|           head values
          961|         else
       error: syntax error, unexpected ';', expecting end of file
       at /nix/store/1xpd4jv46gnaz0yhml02gd90k2apa675-source/home.nix:22:3:
           21|   };
           22|  };
           23| }
my home.nix currently looks like this:
{ pkgs, ... }: {
    pkgs.oh-my-zsh
  programs.zsh = {
   shellAliases = {
    ll = "ls -l";
 oh-my-zsh = {
    plugins = [ ];
    theme = "agnoster";
At the end of the log it shows you the problem.
You have the braces miss matched, one }; too many
Thanks again. New error:
error:
          960|           head values
          961|         else
       error: The option `home-manager.users.shmuel.oh-my-zsh' does not exist. Definition values:
       - In `/nix/store/4b797c6c48qkwf2lkzs01h3i1d7189sq-source/flake.nix':
             plugins = [ ];
             theme = "agnoster";
This one is really easy.
Carefully read this section and then look again at the documentation for that option.
Sorry if I’m not giving you the solution here :wink:
             plugins = [ ];
             theme = "agnoster";
So I added it to flake.nix:
    nixpkgs.url = "github:nixos/nixpkgs?ref=nixos-unstable";
    home-manager.url = "github:nix-community/home-manager";
    home-manager.inputs.nixpkgs.follows = "nixpkgs";
  outputs = { self, nixpkgs, home-manager }: {
    nixosConfigurations.nixos = nixpkgs.lib.nixosSystem {
      system = "x86_64-linux";
      modules = [
      ./configuration.nix
    home-manager.users.shmuel = import ./home.nix;
and now the error is:
error:
       … while calling the 'seq' builtin
         at /nix/store/bg5fbkfa5x53clcjf4p5p92k1l3w8x38-source/lib/modules.nix:322:18:
          321|         options = checked options;
          322|         config = checked (removeAttrs config [ "_module" ]);
          323|         _module = checked (config._module);
         at /nix/store/bg5fbkfa5x53clcjf4p5p92k1l3w8x38-source/lib/modules.nix:261:9:
          260|       checkUnmatched =
          261|         if config._module.check && config._module.freeformType == null && merged.unmatchedDefns != [] then
          262|           let
       error: attribute 'users' missing
       at /nix/store/v8xpbwmgkfaxglskm80m4ryqx0va7lvd-source/flake.nix:15:7:
           14|       home-manager.nixosModules.home-manager
           15|       home-manager.users.shmuel.oh-my-zsh
           16|   {
That was not the problem, the location wasn’t the issue.
Compare the oh-my-zsh config with the one for zsh.
I am obviously not seeing the obvious. :pensive:
Before, I had oh-my-zsh = {
Now I changed it to programs.oh-my-zsh = {
But I get
error:
          960|           head values
          961|         else
       error: The option `home-manager.users.shmuel.programs.oh-my-zsh' does not exist. Definition values:
       - In `/nix/store/ja59753nvfi4lx346srh8xqyg9y2f0qv-source/flake.nix':
             plugins = [ ];
             theme = "agnoster";
Yes that should’ve fixed it but I suspect that you have it in the wrong place.
From what I can see it is now in the flake.nix file.
If you move it back to the home.nix it should work.
It’s a good advice in general when you’re trying to solve a problem.
Only ever change one thing at a time, otherwise you don’t know what exactly made it work in the end.
So if anyone out there has further ideas, this is what I have now:
flake.nix:
      modules = [
      ./configuration.nix
home.nix:
{ pkgs, ... }: {
    pkgs.oh-my-zsh
  programs.zsh = {
   shellAliases = {
    ll = "ls -l";
    plugins = [ ];
    theme = "agnoster";
error:
error:
          960|           head values
          961|         else
             plugins = [ ];
             theme = "agnoster";
The error is referencing flake.nix, but the code snippet that it quotes is in fact in home.nix. This is puzzling.
I looked at the manual and correct would be this:
 programs.zsh = {
   shellAliases = {
    ll = "ls -l";
  oh-my-zsh = {
    plugins = [ ];
    theme = "agnoster";
I missed that it should be nested under zsh, thought it is programs.oh-my-zsh instead of programs.zsh.oh-my-zsh
This would work as well:
 programs.zsh = {
   shellAliases = {
    ll = "ls -l";
programs.zsh.oh-my-zsh = {
  plugins = [ ];
  theme = "agnoster";
Both produce what looks like the same error. I will try to look up the logs.
setting up /etc...
reloading user units for shmuel...
restarting sysinit-reactivation.target
warning: the following units failed: home-manager-shmuel.service
× home-manager-shmuel.service - Home Manager environment for shmuel
     Loaded: loaded (/etc/systemd/system/home-manager-shmuel.service; enabled; preset: enabled)
     Active: failed (Result: exit-code) since Mon 2024-02-19 22:21:16 IST; 89ms ago
   Duration: 2h 11min 12.162s
    Process: 76672 ExecStart=/nix/store/xqfi0hbdgf674hhlw9l2m5bbpd82ysql-hm-setup-env /nix/store/i9dpq3jq5ml6lymihxmnvhwp5g57g1s4-home-manager-generation (code=exited, status=1/FAILURE)
   Main PID: 76672 (code=exited, status=1/FAILURE)
         IP: 0B in, 0B out
        CPU: 71ms
Feb 19 22:21:16 nixos systemd[1]: Starting Home Manager environment for shmuel...
Feb 19 22:21:16 nixos hm-activate-shmuel[76672]: Starting Home Manager activation
Feb 19 22:21:16 nixos hm-activate-shmuel[76672]: Activating checkFilesChanged
Feb 19 22:21:16 nixos hm-activate-shmuel[76672]: Activating checkLinkTargets
Feb 19 22:21:16 nixos hm-activate-shmuel[76761]: Existing file '/home/shmuel/.zshrc' is in the way of '/nix/store/gh5yzl95z2mhp9nwxr060h86nmj9xyq0-home-manager-files/.zshrc'
Feb 19 22:21:16 nixos hm-activate-shmuel[76761]: Please move the above files and try again or use 'home-manager switch -b backup' to back up existing files automatically.
Feb 19 22:21:16 nixos systemd[1]: home-manager-shmuel.service: Main process exited, code=exited, status=1/FAILURE
Feb 19 22:21:16 nixos systemd[1]: home-manager-shmuel.service: Failed with result 'exit-code'.
Feb 19 22:21:16 nixos systemd[1]: Failed to start Home Manager environment for shmuel.
shmuel@nixos:~/nixos/ >
Home-manager doesn’t overwrite files.
Probably your old config is still there?
You can move it to another place and then it should work.
mv /home/shmuel/.zshrc ~/Downloads/zshrc
systemctl status home-manager-shmuel.service
     Active: failed (Result: exit-code) since Mon 2024-02-19 22:21:16 IST; 2min 29s ago
    Process: 76672 ExecStart=/nix/store/xqfi0hbdgf674hhlw9l2m5bbpd82ysql-hm-setup-env /nix/store/>
         IP: 0B in, 0B out
        CPU: 71ms
Feb 19 22:21:16 nixos hm-activate-shmuel[76761]: Existing file '/home/shmuel/.zshrc' is in the wa>
Feb 19 22:21:16 nixos hm-activate-shmuel[76761]: Please move the above files and try again or use>
Feb 19 22:21:16 nixos systemd[1]: home-manager-shmuel.service: Main process exited, code=exited, >
lines 1-18/18 (END)
journalctl -xeu home-manager-shmuel.service
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
░░ An ExecStart= process belonging to unit home-manager-shmuel.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
░░ Subject: Unit failed
░░ The unit home-manager-shmuel.service has entered the 'failed' state with result 'exit-code'.
░░ Subject: A start job for unit home-manager-shmuel.service has failed
░░ A start job for unit home-manager-shmuel.service has finished with a failure.
░░ The job identifier is 33226 and the job result is failed.
lines 129-153/153 (END)
Thanks a million! That was a long one.
You’re welcome, glad we got it working :smiley:
It takes some time to getting used to this work flow.
The great thing is that when it builds it usually works and you have a known good state you can revert to.
Even if you use generations you can always use git to revert to a previous state and built it.
Just be aware that applications that use a database sometimes don’t like it when you revert.
E.g. Signal has a database and it isn’t downwards compatible so you’re either stuck with the new package or remove the database before reverting to the older version.
