I’m wondering if anyone can help me with a problem I’m having with trying to get correct debug-info source code paths when running pluginval
It’s a cmake-built tool that you use to debug audio plugins. I’d like to build it with debug info - including the source files - so that I can run it though LLDB/GDB and see the source code that is being used to test my plugin.
This is what I have in my nix flake to build it:
pluginval = pkgs.stdenv.mkDerivation rec {
pname = "pluginval";
version = "1.0.3";
src = pkgs.fetchFromGitHub {
owner = "Tracktion";
repo = "pluginval";
rev = "v${version}";
hash = "sha256-o253DBl3jHumaKzxHDZXK/MpFMrq06MmBia9HEYLtXs=";
fetchSubmodules = true;
dontStrip = true;
cmakeBuildType = "Debug";
nativeBuildInputs = [
pkgs.cmake
pkgs.pkg-config
buildInputs = pkgs.lib.optionals pkgs.stdenv.isLinux [
pkgs.xorg.libX11
pkgs.xorg.libXrandr
pkgs.xorg.libXcursor
pkgs.xorg.libXinerama
pkgs.xorg.libXext
pkgs.freetype
pkgs.alsa-lib
pkgs.curl
pkgs.gtk3-x11
pkgs.ladspa-sdk
] ++ pkgs.lib.optionals pkgs.stdenv.isDarwin [
pkgs.darwin.apple_sdk.frameworks.CoreAudio
pkgs.darwin.apple_sdk.frameworks.CoreMIDI
pkgs.darwin.apple_sdk.frameworks.CoreFoundation
pkgs.darwin.apple_sdk.frameworks.Cocoa
pkgs.darwin.apple_sdk.frameworks.WebKit
pkgs.darwin.apple_sdk.frameworks.MetalKit
pkgs.darwin.apple_sdk.frameworks.Accelerate
pkgs.darwin.apple_sdk.frameworks.CoreAudioKit
pkgs.darwin.apple_sdk.frameworks.DiscRecording
installPhase = ''
mkdir -p $out/bin
'' + pkgs.lib.optionalString pkgs.stdenv.isLinux ''
cp $(find . -name "pluginval" -executable) $out/bin
'' + pkgs.lib.optionalString pkgs.stdenv.isDarwin ''
mkdir -p $out/Applications
cp -R $(find . -type d -name "pluginval.app") $out/Applications
ln -s $out/Applications/pluginval.app/Contents/MacOS/pluginval $out/bin
The binary file works great and it contains some good debug info but it’s missing some things.
- How do I retain the source code files (.h, .cpp, etc) along with the final binary files so that GDB/LLDB can find them?
- And how do I fix the debug info paths? If I run
gdb pluginvaland theninfo sourcesit prints out where it thinks the source files are. It shows paths like/build/source/Source/CommandLine.cppwhich is clearly wrong and GDB can find no such file - I’d expect a full path starting with /nix/store.
