Help installing acer-wmi-battery (battery protection module)
So I can’t seem to figure out how to install this github package I need to limit my battery to 80%. I already had it installed previously but I forgot how I did it and now I’m stuck.
The url: GitHub - frederik-h/acer-wmi-battery: A linux kernel driver for the Acer WMI battery health control interface
Instructions for installing:
sudo apt install build-essential linux-headers-$(uname -r) git
git clone GitHub - frederik-h/acer-wmi-battery: A linux kernel driver for the Acer WMI battery health control interface
cd acer-wmi-battery
make
I have tried running make with gnumake, linuxHeaders…
For some reason I keep getting errors like this:
mkdir: cannot create directory ‘.tmp_188303’: Read-only file system
mkdir: cannot create directory ‘.tmp_188308’: Read-only file system
mkdir: cannot create directory ‘.tmp_188313’: Read-only file system
mkdir: cannot create directory ‘.tmp_188318’: Read-only file system
mkdir: cannot create directory ‘.tmp_188323’: Read-only file system
mkdir: cannot create directory ‘.tmp_188326’: Read-only file system
mkdir: cannot create directory ‘.tmp_188344’: Read-only file system
mkdir: cannot create directory ‘.tmp_188347’: Read-only file system
mkdir: cannot create directory ‘.tmp_188356’: Read-only file system
ln: failed to create symbolic link ‘source’: Read-only file system
make[3]: *** [/nix/store/6ivk2k90j83iv826p014hw37dml71ba5-linux-6.6.44-dev/lib/modules/6.6.44/source/Makefile:652: outputmakefile] Error 1
make[2]: *** [/nix/store/6ivk2k90j83iv826p014hw37dml71ba5-linux-6.6.44-dev/lib/modules/6.6.44/source/Makefile:798: include/config/auto.conf] Error 2
make[2]: *** [include/config/auto.conf] Deleting file ‘include/generated/rustc_cfg’
make[2]: unlink: include/generated/rustc_cfg: Read-only file system
make[2]: *** [include/config/auto.conf] Deleting file ‘include/generated/autoconf.h’
make[2]: unlink: include/generated/autoconf.h: Read-only file system
make[1]: *** [/nix/store/6ivk2k90j83iv826p014hw37dml71ba5-linux-6.6.44-dev/lib/modules/6.6.44/source/Makefile:234: __sub-make] Error 2
make[1]: Leaving directory ‘/nix/store/6ivk2k90j83iv826p014hw37dml71ba5-linux-6.6.44-dev/lib/modules/6.6.44/build’
make: *** [Makefile:1726: all] Error 2
But I’m not really sure what is wrong.
Consider taking a look at how some other out-of-tree kernel modules are packages in nixpkgs. You’d probably want to do something similar.
