I recently acquired a TP-Link Archer T3U wifi adapter, and it turns out I don’t have the right drivers to use it (when I run nmcli d, the device is not listed). Does anyone with experience with drivers know how I might be able to install the necessary drivers on NixOS?
For reference, here’s what the output of sudo dmesg says about the adapter:
[27047.133985] usb 1-1: new high-speed USB device number 6 using xhci_hcd
[27047.260694] usb 1-1: New USB device found, idVendor=2357, idProduct=012d, bcdDevice= 2.10
[27047.260700] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[27047.260703] usb 1-1: Product: 802.11ac NIC
[27047.260706] usb 1-1: Manufacturer: Realtek
[27047.260709] usb 1-1: SerialNumber: 123456
Tried D-Link adapter for a few hours. Did’t work (I believe it was listed by nmcli). Added the above line. Now works one out of two days. So I’m not sure if this line changed anything but see if a similar line can help you. (After adding your own driver in place of rtl8192eu )
