Greetings,
I’m trying to install the lenovo-legion package and associated kernel module, but can’t seem to get them to work. From my investigation, it would appear that the kernel module isn’t loading. The method I’m using is through the configuration.nix file in which I’d included:
it would appear to me that I’m missing a step or two to actually enable the kernel package from the lenovo-legion-module, but I can’t seem to figure out what to do. I’d attempted to go through the documentation at https://nixos.wiki/wiki/Linux_kernel
The custom module section suggested including
boot.extraModulePackages = with config.boot.kernelPackages; [ lenovo-legion-module ];
Although valid your config is a bit redundant. Since this is the only thing that led me to finding out this package needs a module here’s a more concise configuration with why it is needed:
boot = {
# Kernel
# absolutely don't need this, but use if you want to switch to a different kernel
kernelPackages = pkgs.linuxPackages_latest;
# Kernel modules
# config.boot.kernelPackages already grabs your current kernel version for safety
kernelModules = [ "lenovo-legion-module" ];
