Hi all,
I use Nix + Home Manager on a different GNU/Linux flavor.
I started my learning of Nix Flakes and came out with the following simple flake.nix
, which isn’t working, and I can’t understand what is wrong:
# Description of the flake
description = "CLI apps and tools";
# Define inputs (Nix packages and channels)
# Nixpkgs channel with unstable version
# Home Manager from community repository
home-manager = {
# Define outputs (build results)
outputs = { self, pkgs, home-manager }: {
# Home Manager configuration
homeManagerConfig = {
config, pkgs, ... }: {
# User information
home.username = "cig0";
home.homeDirectory = "/home/cig0";
home.stateVersion = "24.05";
# Enable Home Manager and set options
# ... (Uncomment other programs and configurations as needed)
# Install desired packages
home.packages = with pkgs; [
# ... (Add desired packages from your current config)
#ansible # Using Universal Blue's package
argocd
atuin
awscli2
bat
bitlbee
bitlbee-discord
borgbackup
btop
chezmoi
cargo
chit
cosign
crc
delta
discordo
difftastic
dnstracer
du-dust
dua
duf
dysk
eksctl
exiftool
fd
fdupes
fx
fzf
gh
git-lfs
glab
glances
go
goaccess
golangci-lint
golangci-lint-langserver
gopls
grpcurl
gum
httpie
hugo
hyperfine
inetutils
inxi
iotop
k9s
kind
krew
kube-bench
kubecolor
kubectl
kubernetes-helm
kubeswitch
lazygit
lf
lftp
lnav
lynis
lurk
mc
minikube
moar
ncdu
neofetch
#neovim # Using Fedora's package
nerdctl
nfstrace
nixfmt
nmap
nodejs_latest
nushell
nvitop
oath-toolkit
oh-my-posh
ocm
odo
ookla-speedtest
opentofu
packer
podman-compose
powertop
python312Packages.yamllint
qrscan
ripgrep
rust-analyzer
rust-petname
rustc
rustfmt
rustscan
rustycli
s-tui
shellcheck
sops
strace
strace-analyzer
tcpdump
telepresence2
terraformer
tesseract
tf-summarize
tflint
tfsec
tfswitch
todoist
tokei
translate-shell
ugrep
vagrant
vdpauinfo
vt-cli
weechat
wiki-tui
wl-clipboard
yamlfmt
zola
zoxide
# Enable generic Linux environment variables
targets.genericLinux.enable = true;
I intend to split the flake into other flakes to install the tooling and set environments based on the hostname. However, I first need to get this flake working!
This is the error message I’m getting when nix build .
… while updating the flake input 'pkgs'
error: cannot find flake 'flake:pkgs' in the flake registries
Thanks!
