Hello! I am new to NixOS, but started on a journey to migrate various systems from being managed by a combination of chef and ansible to NixOS.
Something I’m still struggling with is how to organize everything without duplicating too much code. For my flake.nix, this is what I have come up with so far:
disko.url = "github:nix-community/disko";
disko.inputs.nixpkgs.follows = "nixpkgs";
nixinate.url = "github:matthewcroughan/nixinate";
outputs = { self, ... } @ inputs:
with inputs;
system = "x86_64-linux";
nixpkgs = inputs.nixpkgs;
deploy-rs = inputs.deploy-rs;
pkgs = import inputs.nixpkgs {
inherit system;
inherit (deploy-rs.lib) deployModule;
serverConfig = (import ./lib/server-config.nix { inherit pkgs nixpkgs system deployModule inputs; }).serverConfig;
myNodes = {
# These are for use by nixos-anywhere to provision a brand new server
proxmox-one-disk = { hardwareProfile = "proxmox-one-disk"; roleName = "bare"; };
# And then these are individual servers. I need to figure out how to load them from a file or something more dynamic
nixtest1-01 = { hardwareProfile = "proxmox-one-disk"; hostName = "nixtest1-01"; targetHost = "192.168.5.224"; };
nixtest1-02 = { hardwareProfile = "proxmox-one-disk"; hostName = "nixtest1-02"; targetHost = "192.168.5.215"; };
nixtest2-01 = { hardwareProfile = "proxmox-one-disk"; hostName = "nixtest2-01"; targetHost = "192.168.5.227"; };
apps = nixinate.nixinate.x86_64-linux self;
nixosConfigurations = builtins.mapAttrs (name: config: serverConfig config) myNodes;
And then in server-config.nix
, I have:
{ pkgs, nixpkgs, system, deployModule, inputs, ...}:
serverConfig = {roleName ? "default", hostName ? "default-host", hardwareProfile ? "vm", targetHost ? "", sshUser ? "root"}:
nixpkgs.lib.nixosSystem {
inherit system;
modules = [
../configuration.nix
(import ../modules/roles/${roleName}.nix inputs)
(import ../modules/hardware/${hardwareProfile}.nix inputs)
(_: {
networking.hostName = hostName;
# TODO: make this optional
# lib.mkIf (targetHost != "")
_module.args.nixinate = {
host = targetHost;
sshUser = sshUser;
buildOn = "remote"; # valid args are "local" or "remote"
substituteOnTarget = true; # if buildOn is "local" then it will substitute on the target, "-s"
hermetic = false;
I’ve tried colmena, deploy-rs, and now nixinate. So far, nixinate seems to be the deploy tool that requires the least amount of changes. The other tools I kept ending up with duplicate definitions for each server.
My questions are:
- Does what I have so far fall into “standard practices”? i.e. One nixosSystem per server, one “hardwareProfile” for type of server (disk layout, provider, etc), and one roleName for the type of server that includes one or more other modules (enabling docker, nginx, postgres, etc)
- I tried using
_module.args.nixinate = lib.mkIf (targetHost != "") {
and a couple other variations to make nixinate ignore machines without a targetHost defined. Is there a better way to do that? I basically want it to ignore the config profiles that I plan on only using nixos-anywhere with. - Assuming 1. is sane enough, how do I read the list of servers from an external source?
3b. Ultimately I want to read them from Netbox’s API. Can I make api calls like that from inside nix? - Are there any recommended examples or repos that manage a large number of machines? A lot of the repos I’ve seen so far are usually a handful of personal computers and vms
