Hi All,
I’m trying to build a vim plugin that uses remote plugins that require some python packages.
Plugin: GitHub - CopilotC-Nvim/CopilotChat.nvim: Chat with GitHub Copilot in Neovim
vimUtils,
fetchFromGitHub,
python3,
buildEnv,
lib,
stdenv,
makeWrapper,
}: let
pname = "copilotchat-nvim";
version = "1.3.0";
src = fetchFromGitHub {
owner = "CopilotC-Nvim";
repo = "CopilotChat.nvim";
rev = "v${version}";
sha256 = "sha256-vbqtaRejGt+xXi1dfzclKL5/ZynEzBJfqXUHO+sC880=";
meta = {
description = "Chat with GitHub Copilot in Neovim";
homepage = "https://github.com/CopilotC-Nvim/CopilotChat.nvim/";
license = lib.licenses.gpl3;
# Define the Python environment with the required packages
pythonEnv = python3.withPackages (ps:
with ps; [
python-dotenv
requests
prompt-toolkit
tiktoken
# Build the Vim plugin
vimPlugin = vimUtils.buildVimPlugin {
pname = "${pname}-lua";
inherit src version meta;
propagatedBuildInputs = [pythonEnv];
buildEnv {
name = pname;
paths = [vimPlugin pythonEnv];
buildInputs = [pythonEnv];
I found something online that I am using as a base. I can get it to run if I add the python packages to my Neovim config in home-manager. But ideally, I would like to have it neatly packaged and self-contained with this nix expression. How can I make the python packages available at run time to the package, and should I even be using buildEnv?
I am currently getting the following error, when I run :UpdateRemotePlugins
Encountered ModuleNotFoundError loading plugin at /nix/store/id11ap5bpk825l8bvnma4hdfr11mwnjx-vimplugin-copilotchat-nvim-lua-1.3.0/rplugin/python3/CopilotC
hat: No module named 'dotenv'
File "/nix/store/iq776hdh95v2s36z0gqy0sjjinihgg3w-python3-3.11.7-env/lib/python3.11/site-packages/pynvim/plugin/host.py", line 187, in _load
module = _handle_import(directory, name)
File "/nix/store/iq776hdh95v2s36z0gqy0sjjinihgg3w-python3-3.11.7-env/lib/python3.11/site-packages/pynvim/plugin/host.py", line 40, in _handle_import
return importlib.import_module(name)
File "/nix/store/y027d3bvlaizbri04c1bzh28hqd6lj01-python3-3.11.7/lib/python3.11/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1204, in _gcd_import
File "<frozen importlib._bootstrap>", line 1176, in _find_and_load
ModuleNotFoundError: No module named 'dotenv'
remote/host: python3 host registered plugins []
remote/host: generated rplugin manifest: /home/haseeb/.local/share/nvim/rplugin.vim
Clearly, the plugin does not see the installed python packages .
However, if I do the following, it works with my NixVim setup this works.
programs.nixvim = {
extraPlugins = with pkgs; [
copilotchat-nvim
# For copilot-chat
extraPython3Packages = p: [
p.python-dotenv
p.requests
p.prompt-toolkit
p.tiktoken
Thanks a ton!
